What is the best font for v-carving?
I noticed that the v-carving result of letters like an uppercase M do not have sharp angles in the corners, but are made/calculated round.
Are there any standard fonts where the deep carved lines of letter-corners of letters like M,N,K etc. are nice angular and sharp?
Re: What is the best font for v-carving?
Hi Erik!
Are you getting square corners for simple shapes like rectangles etc? What do the corners of a font like Times New Roman look like ? Can you send a photo showing the problem?
V-carving is very sensitive to the quality of the bit, the true angle of the cutter, the accuracy of the Z=surface setting, and the stiffness of the machine. Rounded corners sounds like a cutting problems, not a design issue.
Paul Rowntree
Do you mean the inside corners of the letters or the outside edge? If it's the outside edges then Paul is on the right track.
If it's the inside edges then that's the way VCarving has to work with a round cutter to achieve the outside edge angles.
How does it look in the preview? You can zoom in on the preview to look closely at detail.
If it looks sharp in the preview then you are dealing with mechanical issues such as a bit that doesn't come to a true point, or a machine that is rounding corners.
Try a Times Roman font such as the one used in this test file.
- Test.crv
- (165.5 KiB) Downloaded 853 times
Let me first thank you for your replies.
The round inline corners are what i see in the preview.
The T like in the word 'Tes' is beautifull but somehow I get none perfect 90 degree lines.
Just can not figure out what I did wrong.
Could you post a example of your CRV file?erikwinkler wrote:Let me first thank you for your replies.
Mike
Mike E
CuttingandCarving.com
Hello Mike,
I typed this text in Aspire using normal Times New Roman font.
The red circles show how the toolpath makes round corners out of perfect angled corners. Here you can see that the v-carve bit of 90 degrees does not make perfect square angles as like one would when handcarving. Is there any way to concur this beauty 'mistake'?
As I said in my earlier post that's how VCarving works. With hand carving you're not using a round tool to produce the effect so you won't get the same results.
- FixitMike
This is not a mistake. The VCarve method raises the cutter at the sharp corners so the outline of the letter is sharp. There is no way to achieve what you want except with possibly a very small diameter cutter, say 1/16" doing a pocket cut, and then you will have a 1/32" radius. You cannot get a corner that is sharper than the end of the cutter. Only V bits have sharp ends, and they must be raised to put that sharp point into the corners.
Ok thank you for clearing that up.
- Model of CNC Machine: Probotix Asteroid
Pardon my stupidity but what makes the v bit raise to give this sharp point , when i do Times Roman the bit stays at the same z height and get round so called points.
I read the post but still dont understand what I need to do to get these sharp points
Thank you
Thank you
Are you definitely using a V-Carve toolpath and not a profile toolpath?nikonwalker wrote:Pardon my stupidity but what makes the v bit raise to give this sharp point , when i do Times Roman the bit stays at the same z height and get round so called points.
Thank you
Many thanks , your comment has made it all so clear now , I have only been CNCing with Vectric for 4 months and its been a huge learning experience, learning little things every week, again thanks for the comment
- adze_cnc
erikwinkler,
I've seens this question on these forums a few times before.
To elaborate on what Adrian mentioned, the v-carve/engraving toolpath wants to keep the router bit in contact with two vectors at any given time. This has the drawback of cutting too deep in some areas of text. Note the crossbar for the "A". To the get the results you want it would have to ride on one vector for a small amount of time.
If you truly want a more carved-like appearance you'll have to do quite a bit of vector editing. Attached are two images and a v-carve sample file used to create the images.
There are four layers and four toopaths. The layer "regular v-carve" (currently hidden) goes with toolpath "regular v-carve 90deg" and the three "cut" layers go with there corresponding "[cut]" toolpaths.
Hope this helps in some way,
Steven
Steven
- Model of CNC Machine: pilot pro 2642
Rcnewcomb wrote:How does it look in the preview? You can zoom in on the preview to look closely at detail.
sorry off topic but How are you getting that close with out it being pix-elated????? is there a setting im missing?
