Maloof style rocker
- rscrawford
Maloof style rocker
Finally finished creating the files for a Maloof style rocker. Been working on the files for a year or so, trying to convert one of the rockers I hand carved several years ago into models and cut files. I'll post pics of the jigs and methods I used later.
This is the rocker I used as the 'template'. Here are all the parts laid out, ready to be 'assembled'. Just a little sanding left Fresh coat of finish. Love the look of dark walnut.
Russell Crawford
- rscrawford
Re: Maloof style rocker
Every part except the rockers and the back slats. Those I laminated on forms cut on my Cobra.
The legs each had one dado cut on the table saw. One side of the back legs was rounded over on the router table. The back slats and rockers were rounded over on the router table. Other than that, everything was cut on my cobra.
Russell Crawford
- rscrawford
The armrests were the hardest to design in Aspire. A very organic shape. Two sided machining in Aspire, using dowels to index.
Russell Crawford
- rscrawford
The back legs were a bit tricky, because they angle up towards the headrest. Had to cut them on a tapered jig so the joints would cut correctly.
Russell Crawford
- rscrawford
Didn't take pictures of the head rest being carved, but here are pictures of the model (two sided machining with dowels to index, then a third side machine for mortises)
Russell Crawford
This is magnificent workmanship Russell, and a beautiful chair to boot. The time and thought that you invest in planning these projects really shows well. Projects like this are the perfect antidote to folks who think that CNC is all about mass-production, and not craftsmanship.
Paul Rowntree
- Model of CNC Machine: Shark Pro Plus
WOW !!!
That is awesome. You put in alot of time and thought into that project.
Thanks for sharing.
Thanks for sharing.
Eric
The WoodEraser
Liberty Twp (N. of Cincinnati & S. of Dayton) Ohio
The WoodEraser
- Model of CNC Machine: Roland MDX-40A
Beautiful results with excellent craftsmanship, which we always see in your work. Thanks for sharing, Russell.
Bob
Bob
Bob Armbruster
www.ArmbrusterCo.com
- Model of CNC Machine: 2014 roc-tech 4x8 with servos
if you ever do a 2 or 3 day workshop teaching this, i'd like to attend. that's one of the coolest projects I have seen on this forum. it amazes me how people can figure it all out. beyond impressed on this one.
http://www.3dsigncamp.com
http://www.roctechusacnc.com
- Model of CNC Machine: Shark HD 2.0
I'm am totally amazed at your work. I've seen Maloof's rocker at a show in Pomona at the fair grounds. Beautiful! This is just as amazing.
Rick
Shark HD 2.0
Shark HD 2.0
- TReischl
Incredible! Nicely done!
How soon do you post all the files up here? Huh? Huh? Ok, I will not hold my breath. . . .
- zeeway
Beautiful work. Love Maloof anything. You are my hero.
Angie
Angie
- Model of CNC Machine: Laguna IQ CNC / HHC
Hats off to you, WOW!
Really exciting work! What kind of production do you have in mind? Any rough estimate of machine time per chair? Thanks for showing us!
I thought this was supposed to make life easier?
