More toy cars
More toy cars
Postby dhellew2 » Thu Dec 12, 2013 7:42 pm
Old CAR 2.crv3d
(1.3 MiB) Downloaded 984 times
Old car 1 & 2 fenders 32x5.75x.875.crv3d
(1.96 MiB) Downloaded 959 times
Old car body 1 28.5x5.5x1.25.crv3d
(1.21 MiB) Downloaded 658 times
coupe body.crv3d
(832 KiB) Downloaded 975 times
coupe fenders.crv3d
(284.5 KiB) Downloaded 592 times
Dale
dhellew2
Re: More toy cars
Postby dhellew2 » Thu Dec 12, 2013 7:59 pm
1932 plymouth fenders.crv3d
(1.51 MiB) Downloaded 1411 times
1932 plymouth body.crv3d
(717 KiB) Downloaded 549 times
1930 ford coupe new fenders.crv3d
(1.72 MiB) Downloaded 577 times
1930 ford coupe body.crv3d
(693 KiB) Downloaded 542 times
More toy cars
chev coupe fenders.crv3d
(576 KiB) Downloaded 560 times
chev coupe revised 2.crv3d
(326 KiB) Downloaded 562 times
Dale
dhellew2
Re: More toy cars
Postby dhellew2 » Thu Dec 12, 2013 8:29 pm
A few photos
Dale
dhellew2
Re: More toy cars
Postby jimwill2 » Thu Dec 12, 2013 11:53 pm
Thank you very much! Good looking toys, I'll play with them one of these days.
Jim Williams
jimwill2
Model of CNC Machine: CaMaster Stinger w/recoil, FTC
Re: More toy cars
Postby dhellew2 » Fri Dec 13, 2013 11:38 pm
I believe these .crv3d files can be saved in V-carve format too. If anyone out there wants them let me know, and which ones. Dale
Dale
dhellew2
Re: More toy cars
Postby zeeway » Sun Dec 15, 2013 4:15 am
Well, I went looking for two inch wheels today, and could not find any I liked so...here's one.
Angie
Wheel.crv3d
(339 KiB) Downloaded 476 times
zeeway
Re: More toy cars
Postby dhellew2 » Sun Dec 15, 2013 5:02 am
Way to go Angie! I'll have to try it myself.
Are you going to draw it up for download?
The ones I used on the cars came from:
http://www.caseyswood.com/shoppingcart/ ... ucts_id=83
I drilled out the holes to 23/64" and used 11/32" axle pegs to eliminate wobble.
Dale
Dale
dhellew2
Re: More toy cars
Postby zeeway » Sun Dec 15, 2013 1:25 pm
Hi Dale,
Thanks. I posted the file above for download. I checked out Caseys, but I am in kind of a rush (and I like mag wheels).
Angie
zeeway
Re: More toy cars
Postby bill_w » Sun Dec 15, 2013 5:09 pm
Very nice Angie and thanks for your file
I downloaded it and going to give it a go.
Thanks Bill.
Computers-Yuk....I should junk it...It never does what it should do...only what I tell it.
bill_w
Model of CNC Machine: PRSalpha BT48
Re: More toy cars
Postby dhellew2 » Sun Dec 15, 2013 9:04 pm
Thanks Angie, somehow I overlooked the file. Dale :oops:
Dale
dhellew2
Re: More toy cars
Postby dhellew2 » Sun Dec 15, 2013 9:51 pm
Angie, I suggest using at least a 5/16" axle peg for a 2" wheel. I use 11/32" axle pegs in a 23/64" hole.
A 0.251 hole is a bit tight for a 1/4" axle and if the cars are for kids, a 1/4" axle will break too easy.
The problem with most commercial wheels and axles is wobble i.e. using a 1/4" axle in a 5/16" hole or a 5/16" axle in a 3/8"hole.
A 1/64" clearance (0.0164") is enough if you are using a Tung oil or olive oil finish.
Dale
Dale
dhellew2
Re: More toy cars
Postby zeeway » Sun Dec 15, 2013 10:21 pm
Thanks, Dale. Adjustment made on my end.
Angie
zeeway
Re: More toy cars
Postby dhellew2 » Thu Dec 19, 2013 5:52 pm
In case anyone missed the old posts, after cutting out the parts I round the edges with a router round-over bit. The model radius corners are designed to fit the router bearing.
It is a good idea to drill a 1/16" hole at the bottom-center of the body into the axle hole to relieve air pressure, and for excess glue squeeze out when inserting the axle pegs.
Make a spacer from a plastic lid to prevent inserting the axle peg in too far. Punch a hole and cut a slit into the hole so you can just pull it out once the wheel is in place. Dale
Dale
dhellew2
Re: More toy cars
Postby ibear » Wed Jan 08, 2014 12:35 am
Mr. Dale,
just reading through your posts and looking at the cars from the newsletter. Excellent!!
I would be interewsted in any you would be willing to convert to vcarve fromat.
Lee
ibear
Model of CNC Machine: Homemade from CNCROUTERPARTS PLans
Re: More toy cars
Postby dhellew2 » Wed Jan 08, 2014 5:37 pm
Lee, Look in the v-carve gallery and you will find them already posted. Dale
viewtopic.php?f=5&t=18904
Dale
dhellew2
Next
Return to Aspire - Gallery
Users browsing this forum: No registered users and 15 guests
