1st Try at Firemans Shield
Postby Bacwudz Kustumz » Wed Oct 30, 2013 2:01 pm
Here's my 1st try at the Firemans Shield... Still gotta work on my sanding but not to bad considering it was cut outta pine.
Bacwudz Kustumz
Model of CNC Machine: Shark HD
Re: 1st Try at Firemans Shield
Postby zeeway » Wed Oct 30, 2013 2:39 pm
That really looks good. Very clean cuts, which is tough in pine. Also good finishing job - is that shellac or some other clear sealer?
Angie
zeeway
Postby David Warkentin » Thu Oct 31, 2013 2:43 am
That does look good. Are the flat looking areas on the shield flat so you can vcarve names into them?
David Warkentin
Model of CNC Machine: Camaster Panther 4x8
Postby Bacwudz Kustumz » Mon Nov 04, 2013 2:47 pm
Thanks guys, Its just a spray on poly-stain finish that I rubbed with a greenie weenie to add some depth to the color. I havnt figured out how to carve in the flat areas of the shield yet but I'm working on it. I was actually gonna toss out a question on how to do that with vcarve or cut3D software.
Bacwudz Kustumz
Postby COWBOY1296 » Mon Nov 04, 2013 3:03 pm
I am not sure if this addresses your question or not. Also i am using aspire 3.5 and cant remember the differance in the software.
There maybe better ways, but the way i did it was to draw a circle that looked as if it were centered in the flat areas. Then I created text on a curved line.
COWBOY1296
Model of CNC Machine: SHOPBOT BUDDY PRS 32, 4 FT PWR STICK
Postby Bob Reda » Mon Nov 04, 2013 3:26 pm
With aspire you can project toolpath onto 3d model. I don't know if that is available with v carve or cut 3d. With vcarve I would find the depth of the banner and start the cut at that depth. not sure on cut 3d
Bob
Bob Reda
Postby Bacwudz Kustumz » Wed Nov 06, 2013 2:26 pm
That was what I was going to try it says I can inport vectors from cut3d into vcarve but when I've tried it it doesnt work
Bacwudz Kustumz
Return to Cut3D - Gallery
Users browsing this forum: No registered users and 0 guests
