- JamesB
- Vectric Alumni
Vectric have a dedicated Support section on their website here: https://www.vectric.com/
In this section of the site you will find the following resources to help you work with our software:
Training Videos
Frequently Asked Questions (FAQ's)
Links to Program Updates
System Requirements
A Support Contact Form
Head to the Vectric Community section of the Vectric site for:
FREE Projects
Case Studies
News & Events
Gadgets
Gallery
Along with this forum these are great places to find answers to your questions along with tips and tricks that will help you get the most from the software.
James
Training Videos
System Requirements
FREE Projects
Case Studies
News & Events
Gadgets
Gallery
James
- Model of CNC Machine: CNC Shark Pro HD
Where on the website can I find what software is compatible with Aspire?
thanks,
Chris
thanks,
Chris
- mezalick
Chris,
It's more of what type of file can Aspire work with.....
You can see a list of file types on the Aspire features page.
http://www.vectric.com/products/aspire/features.htm
Also if you click on the import 3d file button in Aspire, there will be a dropdown box with a list of file types that can be imported.
I hope this helps.
Michael
I hope this helps.
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
Hi Chris,
I think you are asking about what file types Aspire can work with? If so, these FAQs should help you:
http://support.vectric.com/aspire-quest ... nto-aspire
http://support.vectric.com/aspire-quest ... e-imported
Some of these types of files are proprietary but others can be produced by many other programs.
Aspire can export 3D models as .stl, .obj and .pov file types and 2D vectors as .dxf, .eps, .ai and .svg.
Tim
Tim
- mezalick
Thanks Tim,
I need to bookmark those pages......
I know they were around somewhere,,,just couldn't find them this AM..
Michael
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
I am really asking what types of programs that generate g code, like mach 3 are compatable with Aspire. I now have a cncshark, which has its own proprietary software, which I know will work. However, if I get a different machine, what software would I use? I'm sorry to be so ignorant on this, but I have only used Vectric products on the Shark.
- Model of CNC Machine: ShopBot prt with 4g upgrade
Chris, It is the post processor that determines the output of the aspire files ... and there is a lot
so compatible with a lot of machine its easier if you say what you what you are looking at .
I used Mach 3 and now have Shopbot . Just changed the PP
"Aspire can export 3D models as .stl, .obj and .pov file types and 2D vectors as .dxf, .eps, .ai and .svg."
Curious as to where it says on the Vectric web site that Aspire can "Export" models in a STL format. I currently have Aspire to 2.5 and would jump at an upgrade if I can indeed export in STL.
There are many other good reasons to upgrade but you may be interested to know you can export in STL from V2.5. Open the Model pull down menu from the main menu and select "Export as STL".I currently have Aspire to 2.5 and would jump at an upgrade if I can indeed export in STL.
Version 4 had added the additional 3D export file types.
Tim
YES - Aspire 4 can indeed export STL.
I just exported an STL - then imported it into Solidworks.
Tim and Leo
I would like to thank you both. Guess I have been spending too much time doing 2D stuff in Aspire.
FYI, the reason I am interested in exporting in the STL format is that I am going to get a 3D printer soon and think it would be cool to use Aspire to create some interesting projects.
And yes, I will be upgrading to Aspire 4.0 anyway.
Larry
Larry
Larry, the sign I did in the STL view was totally done in Aspire. I used NO other software. I exported the STL and imported to Solidworks only to show that is CAN be done.
- Model of CNC Machine: Legacy Maverick 4x8, BOSS laser
December 2013 update
Today, 12/6/2013, I asked Aspire 4.015 to check for updates.
It said it updated some data files.
Is there somewhere I can find out what was updated?
Chelmite
Chelmite
- Model of CNC Machine: home built
thanks for all your help, but where can I find a tutorial on how to use GIMP
http://www.gimp.org/tutorials/Roy Esslinger wrote:thanks for all your help, but where can I find a tutorial on how to use GIMP
Paul Rowntree
