Clocks
Gallery for samples created from Vector Art 3D Machinist or using Design & Make projects
Moderator: Todd Bailey
Clocks
Postby ohiococonut » Wed May 22, 2013 2:43 pm
I'm still learning the in's and out's of Aspire (there's a Lot to learn) but I thought I'd share a couple of clocks I recently made. The first one is the deer scene on a walnut slab. The second one is comprised of pheasants on crotch walnut. Surprisingly they keep very good time.
ohiococonut
Re: Clocks
Postby GaryR6 » Wed May 22, 2013 4:24 pm
Nice tic toc's
GaryR6
Re: Clocks
Postby WoodEraser » Wed May 22, 2013 5:11 pm
Nice clocks and nice job.
Eric
The WoodEraser
Liberty Twp (N. of Cincinnati & S. of Dayton) Ohio
WoodEraser
Re: Clocks
Postby tonydude919 » Wed May 22, 2013 6:56 pm
Nice work,like the slabs.
Tony
tonydude919
Model of CNC Machine: cnc mako shark ext bed with HD 5 gantry
Re: Clocks
Postby rsetina » Sat May 25, 2013 6:26 am
Beautiful!
Rick
Shark HD 2.0
rsetina
Model of CNC Machine: Shark HD 2.0
Re: Clocks
Postby ohiococonut » Sat May 25, 2013 12:34 pm
Thanks for the compliments. My shop walls are filling up since I really don't sell anything, it's just a hobby.
It's amazing how much time and effort I will put into creating something and not take the time to even use a camera to take pictures. My cell phone is always with me and even though it doesn't take very good pictures I still continue to use it :roll:
ohiococonut
Re: Clocks
Postby joeporter » Sun Jun 02, 2013 2:32 pm
Nice work and great ideas. I have become a clock junkie and my walls also are starting to fill up...joe
joeporter
Re: Clocks
Postby oldlogtrucker » Tue Jun 04, 2013 6:04 pm
What method do you use to keep the bark from chipping off of your slab?
Thanks Kathy
Embroidery - WingsXP
oldlogtrucker
Model of CNC Machine: Cam Master StingerII
Re: Clocks
Postby esteeme1 » Wed Jun 05, 2013 5:02 am
Excellant pieces and great finishes.
Jim Darlas
"Can Do!"
esteeme1
Re: Clocks
Postby Alan Male » Wed Jun 05, 2013 8:56 am
Lovely job.
Do you rout out the back to take the quartz mechanism?
Cheers - Alan
CNC m/c - Heiz 400T
CAD - Catia V5
Alan Male
Model of CNC Machine: heiz 400T
Re: Clocks
Postby ohiococonut » Thu Jun 06, 2013 12:15 am
Thanks Kathy
I'm real careful when cutting and when I'm finished I coat the entire project with 3-4 coats of shellac and finish with 3-4 coats of satin polyurethane. Since the bottom one was completely carved I finished it with 5 coats of tung oil.
Lovely job.
Cheers - Alan
Yes I do. it gets a little tricky trying to figure out how deep I need to pocket it as well as how deep to carve the opposite side depending on the length of the clock stem. I like to keep them flush or a little below flush so they hang flat on the wall.
ohiococonut
Re: Clocks
Postby ttolli » Sun May 18, 2014 12:42 am
You wouldn't consider sharing the files for the recess in the back would ya !!!
Tim
ttolli
Model of CNC Machine: Shark Pro Plus Hd
Re: Clocks
Postby esteeme1 » Sun May 18, 2014 3:06 am
Hey Tim I'm pretty sure those have copy rights.
Jim Darlas
"Can Do!"
esteeme1
Re: Clocks
Postby ohiococonut » Sun May 18, 2014 12:02 pm
Tim,
The pockets on the back are no secret and a pretty straight forward process. When I'm cutting out the design I normally use a 1/4" end mill and use tabs. The hole where the stem will protrude is usually a separate cut file that's the size of the stem that I cut completely through the material. When it's cut, try fitting the stem into the hole. If not, enlarge it slightly.
When I'm finished with the top, and before I separate it from the tabs, I flip it over exposing the hole on the backside. I set the project back on the table, run the 1/4" end mill down through the hole to square up the project, clamp, and cut a pocket about 3/16" larger than the clock mechanism and the depth to allow it to sit flush.
The depth of the pocket depends on the thickness of the mechanism you're using. The hardest part, if you want to keep it flush with the back, is figuring out if your material is thick enough. You need to add the thickness of the mechanism then allow for the depth of cut on the front, if you're doing 3D, and buy the mechanism with the right length stem or you have to change the depth of cut on the front.
These little clock mechanism come with different length stems and you can pick them up at most hobby stores for about $5. I have several in different sizes and get mine from Clockit.
You can turn literally any project into a clock. I hope some of this made sense.
ohiococonut
Return to Design & Make Clipart - Gallery
