New Machine
The Gallery is for posting photographs and images of work machined using Cut2D
RonH
New Machine
Post by RonH »
After 3 months I now have my new cnc machine done. Came out well I think. Its very fast and very smooth. As you can see I built a vacuum box for it. I purchased Aspire for it so will I hope make some nice stuff...Ron
mboydraska
Model of CNC Machine: 3 axis homebuilt
Re: New Machine
Post by mboydraska »
Very nice machine, I like the vac box setup, did you use peg board or drill every hole?
HAPPY CUTTING
Mike
RonH
Re: New Machine
Post by RonH »
mboydraska wrote:Very nice machine, I like the vac box setup, did you use peg board or drill every hole?
I drew up the holes on cad and it cut them out for me. 7000 plus holes. Glued pegs under it to keep from sagging and put lath stiffners on it also. Works very well...Ron
GaryR6
Re: New Machine
Post by GaryR6 »
Your own design? What are the specs? http://www.vectric.com/forum/posting.ph ... =19&t=9348#
RonH
Re: New Machine
Post by RonH »
GaryR6 wrote:Your own design? What are the specs? http://www.vectric.com/forum/posting.ph ... =19&t=9348#
The table has an y width of 50 inches and the x axis is also 50 but of coarse you can put a sheet of plywood on it if you want too. All motors are 360's and are running on 48 volts with a gecko running the whole show. Rack and pinion on the x and y axis with an acme running on the z axis. This machine if turned loose can move at over 1000 inches per min. Its scary to see it move so fast. I have it slowed way down and its a very smooth quick running machine. It is pretty much my own creation as much as one can be ones own. The use of 80/20 made building it simple and strong. It has both cut 2D and Aspire installed on it. I am learning to use Aspire at this time and so far its been fun. While it could have been done faster I took about 3 months to build it. While not something you would do every day the cross member can be moved vertically to accomidate a large object such as a post or piller. I think it was worth the money and time to build it and now I have two machines I can operate. The old JGRO is doing good and still works well. Just won't be used as often. Thanks for you question...Ron
aironeous
Model of CNC Machine: HAAS
Re: New Machine
Post by aironeous »
I want a big one like that but not with the computer set up in that way it looks un-ergonomic for me (I'm 6'1") I'd have a desk for the PC next to it somehow. I hope I will build something like that in the future. Right now, first, I have to get experience just setting up and using a pre-made desktop one and mach3 with a smooth stepper.
I really don't know where all you guys are getting these pc's with a 25 pin printer port on them. I see some older laptops & desktops with 9 pins but no 25 pins and many of you do not mention a smooth stepper which is making me scratch my head because you seem light years ahead of me in CNC'ing yet you all have some kind of super old PC with a 25 pin port and it still runs mach3 and gives you no problems? Is there some kind of card you can buy that will insert a 25 pin serial port on your machines and you guys just never mention it?
sawdust57
Model of CNC Machine: laguna swift 4 x 4
Re: New Machine
Post by sawdust57 »
What are you using to pull the vacuum with? tks. :?:
Ms Wolffie
Re: New Machine
Post by Ms Wolffie »
I don't understand vacuum boxes :?
With all those holes, when you put a smaller size workpiece on the table how do you stop the air from escaping through the unused holes?
If you need a spoilboard with clamps, what's the point of a vacuum box?
Cheers
Wolffie
Cheers
Wolffie
Whatshammacallit
oddname
Model of CNC Machine: MechMate - DIY
Re: New Machine
Post by oddname »
Clamps = good for larger/heavier pieces.
Vacuum = good for smaller/lighter/thinner pieces so they dont fly away or get damaged when clamping
JimG
Model of CNC Machine: Seig KX1
Re: New Machine
Post by JimG »
aironeous wrote: I really don't know where all you guys are getting these pc's with a 25 pin printer port on them. I see some older laptops & desktops with 9 pins but no 25 pins and many of you do not mention a smooth stepper which is making me scratch my head because you seem light years ahead of me in CNC'ing yet you all have some kind of super old PC with a 25 pin port and it still runs mach3 and gives you no problems? Is there some kind of card you can buy that will insert a 25 pin serial port on your machines and you guys just never mention it?
You can get cards to give you a parallel, 25 pin port. I fitted one to a PC I got for my Mach3 installation and it works well. I don't know your setup, but with Mach3, certain parallel port cards don't work with it, so you might have to check out any card you intend getting to make sure it will work with your PC and controller.
Jim.
Norb
Model of CNC Machine: MAXI-C 1530 SE-T-V
Re: New Machine
Post by Norb »
JimG wrote:
.........but with Mach3, certain parallel port cards don't work with it........
Jim.
This helped me http://www.cnc4pc.com/Store/osc/product ... cts_id=203
Norbert
Aspire 4.x, PartMasterCAM Turn, Autocabinets
after hours: Sherline 2010 and 4410
fretsman68
Re: New Machine
Post by fretsman68 »
A good thread on the parallel port for Mach 3 is here:
http://www.machsupport.com/forum/index. ... 300.0.html
If you didn't feel like reading, here are 2 cards that are proven to work.
http://www.newegg.com/Product/Product.a ... 6815124083
http://www.newegg.com/Product/Product.a ... 6815166007
Dave
Dave
