saving a 3d image and using it in another project
Tips, tricks and questions about the free Design and Make 3D Machinist from https://store.designandmake.com/ - Design & Make projects
Moderator: Todd Bailey
tiofilo123
Model of CNC Machine: 5X10 Industrial Cnc
Post by tiofilo123 »
Hello all new here
I recently purchased aspire and think its the greatest thing everrr!! I currently created several 3d's of quail and a dog, I created them separate and saved them. Now I want to create a plaque and incorporate these files into it, but everytime i try to open them it erases my plaque and inserts my dog or quail. Am i saving them wrong
thanks
gravirozo
Re: saving a 3d image and using it in another project
Post by gravirozo »
open 2 copy of aspire... (2 instance) at time... in the first create your plate, in the second (instance) open the dog...
select dog (as component) and copy, right click on the selected greypicture, and in the popup menu select copy...
go in the other open aspire, right click in the 2d window, any clear point, and select paste...
when both model is in, then you can align them to each other and set both to add or merge...
viktor
Sounds like you're trying to open rather than import the second file which replace the first one.
You should use the Import Component/3D Model item instead of Open.
