Just a note that we added another model that really benefits from having the text engraved into it. The model on the site is a Special Forces Emblem which you can see here:
http://www.vectorart3d.com/store/index. ... l&ID=57274
The vectors for the text for the different styles of model are attached to this post in a zip file below. You can also see an image showing an example toolpathed in Vector Art 3D Machinist for the 3D then with the text engraved onto it using the eps file in VCarve Pro (this could also be done in Aspire - along with modelling the text if you wanted).
Cheers,
James
Vectors for Special Forces Emblem
Moderator: Todd Bailey
- JamesB
- Vectric Alumni
- SpecialForcesText.zip
- (35.84 KiB) Downloaded 328 times
