Thanks for the free machining program. Very nice.
I will be buying some models soon !!
This was cut in corian with a 3/8" ballnose, its all I had. Took about 9 mins.
This 3D can get addicting !!
I have a couple of questions for 3d cutting.
What are the best settings for a 1/8" ballnose as far as stepover?
Can a v-bit be used to get fine details?
First 3D Part test !
Moderator: Todd Bailey
- JamesB
- Vectric Alumni
Best settings for a 1/8" ball nose for stepover is 10% or 0.0125", I know some people that like to take this down to 8% for a really fine finish. A Vbit is not really suitable as you need such a small stepover to make it smooth that it increases the time significantly. For relatively small work like this you may want to go down to a 1/16" diameter bit to get more detail.
James
James
