Dealing with unwanted vector boundaries
Tips, tricks and questions about the free Vector Art 3D Machinist from www.vectorart3d.com or Design & Make projects
Moderator: JamesB
Postby JTEagle » Sat Aug 18, 2018 11:02 pm
I'm doing a project using Design and Make wildlife models. Started with making log stile frame and then done the layout. When I do the toolpath everything is fine until the profile pass. When doing the vector boundary tool it does both inside and outside boundaries of the frame. I just need the outside vectors profile cut, if I cut the inside the layout will fall from the frame. So how do I delete the inside vectors so it won't be cut?
Thank you all for any and all help,
JTEagle
Model of CNC Machine: Axiom Autoroute Pro 8
Re: Dealing with unwanted vector boundaries
Postby highpockets » Sat Aug 18, 2018 11:38 pm
If I understand what you want to do....
Ungroup the boundary vectors and delete the vectors you don't want to use....
Postby JTEagle » Sun Aug 19, 2018 12:02 am
Yes Highpockets that is what I'm trying to do. Just need to profile cut on the outside of the frame. I have tried to upload the file and pictures but every time I do it kicks me out of the message board.
Thank you,
JTEagle
Postby highpockets » Sun Aug 19, 2018 12:11 am
Here's an example....
I don't know what your model is, but this will do.
After creating the vector boundary you'll have two (or maybe more) vector boundaries in a group.
Click on the vector boundary and right mouse click then select Ungroup. Note: you can also just press "U" to ungroup the vectors.
Then just choose the vectors you don't want and delete them.
Hope this helps.
Postby JTEagle » Sun Aug 19, 2018 2:02 am
highpockets,
Thank you very much for the help, I will give that shot and see what happens .
JTEagle
Postby JTEagle » Sun Aug 19, 2018 2:19 am
highpockets,
The info you gave me worked like a charm and thank you.
JTEagle
Postby highpockets » Sun Aug 19, 2018 2:35 am
Happy to help....
Return to Vector Art 3D / Design & Make - General
Users browsing this forum: Paul_n and 4 guests
