Stopping and re-starting a 8 hour + design and make project
Tips, tricks and questions about the free Vector Art 3D Machinist from http://www.vectorart3d.com or Design & Make projects
Moderator: Todd Bailey
Postby jamink » Wed Apr 18, 2018 4:06 pm
I am using V-carve pro 9 with a design and make 3D project.
My design will take over 11 hours to carve. Size of my design is 12"x20". Does anyone know how to carve in 3-4 hour blocks instead of having it carve for 11 hours?
jamink
Model of CNC Machine: shark black diamond
Re: Stopping and re-starting a 8 hour + design and make proj
Postby adze_cnc » Wed Apr 18, 2018 4:44 pm
Does your machine's controlling software allow you to stop and resume on a specific shape or on a particular line of g-code?
adze_cnc
Postby jamink » Wed Apr 18, 2018 7:20 pm
I can pause the cnc shark which keeps the router running. I can do an emergency stop but not sure if it will restart in the exact same spot it stopped.
jamink
Postby AlanAndrews » Wed Apr 18, 2018 10:35 pm
I had similar issues on my ELU860 machine.
When I knew I had a long running job, I often made a copy of the g code file that I would edit to make a part 1 and part2 file split at a particular line number, so that I could run to ensure I was in control of the machining.
I have since replaced all of the control/driver/motors etc so that I can pause and restart without the risk of losing position. This includes if I lose power.
The new controller allows me to pause or stop the machine code any where, and restart without the risk of losing position. I spent quite a bit of time making sure that I was achieving this functionality.
The new closed loop motors also ensure that I will not skip steps when processing.
AlanAndrews
Model of CNC Machine: ELU860
Postby Leo » Thu Apr 19, 2018 3:54 pm
I have edited files in the past.
You CAN make a tiled toolpath to split up the long running program. I works quite well.
www.leosworkshop.com
Leo
Postby bbiehl » Thu Apr 19, 2018 5:25 pm
If your are running Mach3 you can restart if you know the line number of the G-code where it stops. On the Mach screen there is a "Run From" window. Click on that window. A keypad window will pop up. Type in the G-code number. Hit okay. Then hit "Cycle Start"
The G-code will start scrolling from line 1, etc. until it gets to the line # you typed in the "Run From" window, your machine will then start running.
-brian
bbiehl
Model of CNC Machine: Legacy Arty 58; Aspire 9.0
Postby Jozua » Thu Apr 19, 2018 6:02 pm
jamink wrote:My design will take over 11 hours to carve. Size of my design is 12"x20".
I am a little confused about your design and the time estimate. How complex is it?
I recreated you project size and pasted as many 2,5D objects as I could fit into this pace.
For me at a slow 100 IPM this takes only 1 hour 37 minutes.
I use Aspire 8.5 but I am sure it is the same for V Carve Pro.
Are you sure that you have your Scale factor correct?
Cut something small and compare the real time on your machine versus the time estimate in V Carve Pro.
I hope this helps.
Joz
Jozua
Model of CNC Machine: EZ-Router
Postby jamink » Wed Apr 25, 2018 4:15 pm
Thanks Joz for the tip. I did reset the scale and it did cut the time down to 8.5 hours. Yes the design is complex. I will have to try to tile the design. I will also explore adding g-code, if I can, to run in separate sessions. I will post the outcome after I try those things.
Thanks everyone,
Jam
jamink
Postby adze_cnc » Wed Apr 25, 2018 4:55 pm
jamink wrote:I can pause the cnc shark which keeps the router running.
The router has an on/off switch? If it does then turning it off while paused and turning back on when you want to restart the job seems easier than editing g-code or tiling the job.
adze_cnc
Postby jamink » Tue Jul 10, 2018 2:49 pm
Thanks for all of the ideas.
I ended up tiling the job and set the tiles to 4 inch segments with each being about 2 hours long. This worked great.
I contacted CNC Shark support and they are working on a way to stop the carving and re-start at a later date. At this point we can not do that.
jamink
Return to Design & Make Clipart- General
