3D boundary offsets
Tips, tricks and questions about the free Vector Art 3D Machinist from http://www.vectorart3d.com or Design & Make projects
Moderator: Todd Bailey
3D boundary offsets
Postby murietamike » Tue Oct 24, 2017 7:08 pm
When using the Vectric clip art with Vcarve pro, how do I determine the cut depth on the parameter? I noticed on the 3D roughing and the 3D finishing tool paths, there are boundary offsets. When I set these to .15 it came close to cutting through but gave me a nicer edge. Although, anything greater will cut through. What's the secret to this?
murietamike
Model of CNC Machine: Laguna tools IQ
Re: 3D boundary offsets
Postby Adrian » Tue Oct 24, 2017 7:37 pm
To cut the piece out you would generally use the Create Vector Boundary tool to create a vector that can be used to create a profile toolpath.
The boundary offset is generally set to the tool radius to ensure the tool "rolls over" the edge of the model to ensure it is properly finished.
Postby murietamike » Tue Oct 24, 2017 7:54 pm
That's what I thought but if I set boundary offset to .25 (using a .25 end mill and a .25 ball nose) it cuts through my material on the outside parameter during the finish cut. It shows that on the previews also. Am I missing something?
murietamike
Postby Adrian » Tue Oct 24, 2017 8:09 pm
If the model is the same thickness or less than the material then the finishing toolpath will go all the way through as it rolls over the edge. That is expected behaviour. You can use 3D tabs to hold it in place.
Postby murietamike » Tue Oct 24, 2017 9:07 pm
I appreciate the info. I'm not sure what you mean by adding the 3D tabs. Are you talking about adding them at a profile cutout in 2D? Wouldn't the ball nose take them out too?
murietamike
Postby Adrian » Wed Oct 25, 2017 8:16 am
3D tabs when it comes to a model are a different thing. They are shapes that can be added to a model. They are in the download section of your portal account.
Postby mtylerfl » Wed Oct 25, 2017 3:34 pm
murietamike wrote:I appreciate the info. I'm not sure what you mean by adding the 3D tabs. Are you talking about adding them at a profile cutout in 2D? Wouldn't the ball nose take them out too?
Take a peek at the video tutorials. One I know that uses 3D tabs is the two-sided Swordfish. Doesn't matter one-side or two-side. Just watch to get the idea.
The October 2017 project of the Month has a Deringer replica that is a one-side project layout. I used 3D tabs for the three components to be held in, even though it is a "pierced" layout, meaning the Finish toolpath goes through the material (except where the tabs are of course).
carvebuddy.com
Postby murietamike » Wed Oct 25, 2017 5:05 pm
Great. Thanks again.
murietamike
Postby murietamike » Wed Oct 25, 2017 10:14 pm
Help again please. I logged into the vectric portal and I don't see where to download the 3D tabs. Also, where can I find the clip art I downloaded?
Thanks again
murietamike
Postby mtylerfl » Wed Oct 25, 2017 10:53 pm
murietamike wrote:Help again please. I logged into the vectric portal and I don't see where to download the 3D tabs. Also, where can I find the clip art I downloaded?
Thanks again
When you have logged in to your portal account, you should see a list of several clipart installers which includes one named "V9 3D Tabs Clipart for VCarve"
You asked "...where can I find the clip art I downloaded?" The clipart downloads are executable files. Run the .exe file(s) and the clipart will be installed for you automatically. Next time you open your VCP, the clipart should appear via the Clipart tab in the software.
carvebuddy.com
Postby murietamike » Wed Oct 25, 2017 11:13 pm
I logged in at this address https://portal.vectric.com/account and it gives me a welcome to V & CO. I don't see any clip art installers. I don't remember this page.
murietamike
Postby mtylerfl » Wed Oct 25, 2017 11:24 pm
murietamike wrote:I logged in at this address https://portal.vectric.com/account and it gives me a welcome to V & CO. I don't see any clip art installers. I don't remember this page.
After you select the product you own, a page should display where you can access your downloads. I did a partial screenshot of my portal page (cropped off my username and pass, etc.)
Does your portal download page look different? It should look about the same or similar (although I'm not sure my download list will be exactly the same as yours.)
carvebuddy.com
Postby murietamike » Thu Oct 26, 2017 5:05 am
I finally found it. Thanks for hanging with me. What is the V9 3D tabs clipart for Vcave on your list? I have the 3D tabs but not that one.
Thanks again
murietamike
Return to Design & Make Clipart- General
