The finish cut not deep enough
Tips, tricks and questions about the free Vector Art 3D Machinist from http://www.vectorart3d.com or Design & Make projects
Moderator: Todd Bailey
Postby good1 » Sat Apr 01, 2017 9:23 pm
When looking at the preview tool paths in the selected tool paths, the finish cut looks like it is not cutting deep enough. There are areas where it is cutting
deeper (where it should) than the area where it is not cutting deep enough. Is there a way to have the z axes cut, say about .02 deeper? Thanks gene
good1
Model of CNC Machine: Shark black Diamond
Re: The finish cut not deep enough
Postby Bob Reda » Sun Apr 02, 2017 10:58 am
you can fool the machine. After zeroing move the z to -.02 and then re zero.
Bob
Bob Reda
Postby Adrian » Sun Apr 02, 2017 11:10 am
It might not be cutting as deep as you want as the tool can't fit into those areas. Try previewing with a smaller tool and see if it makes a difference.
Return to Design & Make Clipart- General
