Wine pairs nicely with a D&M CNC project!
Tips, tricks and questions about the free Vector Art 3D Machinist from www.vectorart3d.com or Design & Make projects
Moderator: JamesB
Postby Todd Bailey » Thu Sep 29, 2016 7:14 pm
This post is for all the Design and Make enthusiasts out there!
Just a quick post to keep you up to date on what is new over at www.DesignandMake.com.
Introducing our latest project - Wine Bar No.2 - http://designandmake.com/wine-bar-no-2
11 models, 1 assembled layout and 3 Project Sheets. All offered in .V3M format for VCarve Pro 8, VCarve Desktop or Aspire.
All the models can be machined separately, combined to make a much more complicated part or hacked together with other project models or some from your own library.
A little Bonus
We have included 2 extra Project Sheets to help you get up and using this project faster the never.
- The plan for the perfect wine bottle coaster - will help you get the right setup so that your bottle will fit perfectly.
- Information on how to use the project to create a wine themed candle holder.
Take a look at our weekly hacks... http://designandmake.com/hacks/
Check out what other Design and Make users have been up to - http://www.weekendcncwarrior.com
Don't forget to follow us on:
FB - https://www.facebook.com/designandmakeit
Twitter - https://twitter.com/DesignAndMakeIt
Be safe and let the chips fly!
Possible Layout
Another Possible Layout
All 11 Models
Assembled Layout
Check out this Project Hack
Finished Wine Bottle Coaster by Don Harding!
Todd Bailey | Design and Make
DesignAndMake.com
Todd Bailey
Vectric Staff
Model of CNC Machine: CraftCNC
Re: Wine pairs nicely with a D&M CNC project!
Postby madriano » Tue Feb 07, 2017 5:13 pm
I'm a newbie here and am just starting out with my CNC Shark and Vcarve Desktop 8.5 software. I took the plunge and purchased a few items from D&M, Wine Bar 2 is one of them. I follow all the steps as in the video, when I machine the rough carving the machine works fine, when I go to the finish tool path the machine tries to move to a totally different location then the rough toolpath. I checked the X & Y locations within the software, they are located in the bottom left corner, so I'm not sure what I'm doing wrong. Any help would be appreciated.
Mike
madriano
Model of CNC Machine: Shark
Postby mtylerfl » Wed Feb 08, 2017 3:19 am
Hi Mike,
Did you move anything on your layout after calculating your toolpaths? Maybe your design layout was in one location when you calculated the Roughing, then you moved the design and then calculated the Finish Toolpath? Doing so would make the Roughing and Finishing to be in separate locations. Try re-calculating ALL your toolpaths and see if that fixes the problem.
Be sure to run the Toolpath Preview to verify everything is carving exactly as you planned. In fact, you should have been able to see whether the Roughing and Finishing Toolpaths were "off" from each other by watching the Preview initially.
Please holler if you have other questions.
Postby madriano » Wed Feb 08, 2017 2:21 pm
Nothing was moved but I started getting an error now, after some research I was able to determine that the power on my USB port (new computer) is either low or fluctuates. I purchased a USB Hub (amplified / powered) which appears to have corrected all the issues I've been having. Just odd that the roughing pass worked and any second attempt would fail.
Thanks for the reply!
Mike
madriano
Postby mtylerfl » Wed Feb 08, 2017 3:08 pm
I'm glad to know you found the problem and are up and running again! Excellent news!
Return to Vector Art 3D / Design & Make - General
