What is the difference between 4 flute and 2 flute ball end router bits in relation to carving? Which is better to use. Also, what is the difference between coated and not coated? I read through the sites and it doesn't explain what the differences are.
Bob
Router bits
Moderator: Todd Bailey
- Thkoutsidthebox
In relationship to wood, the two flute would allow for a more agressive cut. A four flute would load up which in turn could burn.
At 20k rpm a bit has to cut the wood and get the chip away from the material so the next flute can do its job.
I have used four flute center cutting with a high helix to do pockets and it worked fine...but I prefer two or one flute for most wood.
If you are running more flutes you can run your router at a slower rpm or cut at a higher speed. There are chip load formulas and test out your feeds and rpms to double check. A 2 flute 3/8 end mill I run at 18000 rpms on my machine where as the 3 flute I run at 13000. The 3 flute makes less noise because it is running slower so I use them alot.
Mark M
Mark M
- WillyInAus
Do you find much difference in the cut at slower speeds, noise is a real problem for me and cutting at 1300rpm would be good if I could.Markm wrote:If you are running more flutes you can run your router at a slower rpm or cut at a higher speed. There are chip load formulas and test out your feeds and rpms to double check. A 2 flute 3/8 end mill I run at 18000 rpms on my machine where as the 3 flute I run at 13000. The 3 flute makes less noise because it is running slower so I use them alot.
Mark M
