The Tech Shop in my city is using Aspire and I purchased a 3d model from vectorart3d.com.
The cutting area is smaller than actual overall size I want. No issue with the Z heights. It's the Y axis which I come up short.
Is it possible to slice the 3d model? Or how would I go about aligning 2 separate sections on the table?
Rod
How to slice 3d model purshased at vectorart3d.com in the Y
Moderator: Todd Bailey
Re: How to slice 3d model purshased at vectorart3d.com in the Y
Try Toolpath Tiling - Video 10 on this page - http://www.vectric.com/support/training ... -mach.html
It's designed for projects that are bigger than the toolbed so should do what you're looking for.
Perfect.
thank you.
Rod
thank you.
Rod
