Well
I cut the first pocket works awesome, cut the second path works great, try to cut the circle pocket and instead of it cutting the 1.875 hole it starts a huge 4 inch or so path.......
Not really sure why, I have re-drawn it 2 times and it still cuts a large diameter
Problem with a file could use some guidance
Moderator: Todd Bailey
- New.crv
- (378 KiB) Downloaded 339 times
- Ken Rychlik
- Model of CNC Machine: Buy, fix, and sell them
Re: Problem with a file could use some guidance
The two circles are drawn at 2.125
If they are cutting a different size AND you are using the same bit you designed it with,,,, then there could be an issue with the machine/postprocessor arcs settings.
What brand of cnc are you using, what post processor are you running on it, and that kind of info would help.
Custom CNC Work
Local Machine Repairs and Programming
Well I thought it would be important to just post the resolution to close this out. A few years ago I wrote down the settings of the machine (arcs, scale, table dimensions, etc.) I believe it is the called the machine settings (A great idea BTW). Never thought the settings could get dumped but they did. I entered the settings for machine (post processor) back into the interface and BooM it worked again. So lesson learned back everything you enter into the machine settings for times like this.
