size
size
Postby oginok » Sat Feb 09, 2019 3:48 pm
brand new to PVC and forums.(first post) Here it is, I've got pic ready to carve, post it, load it, and where my size was supposed to be about 4.0 in. x 4.5 in., program runs pic about .125 square. maddening. What am I missing?
oginok
Model of CNC Machine: Shark HD4 extended
Re: size
Postby mtylerfl » Sat Feb 09, 2019 3:50 pm
Are you swapping inches for millimeters?
Re: size
Postby oginok » Sat Feb 09, 2019 7:14 pm
don't think so.. on PVC lower right says 4.461 x 4.0 inches and shows toolpath across pic and g code reflects one instance of approx. 3 in movement.
oginok
Re: size
Postby mtylerfl » Sat Feb 09, 2019 7:16 pm
Check that you are using the correct post processor and that your controller is set for inches too.
I still think somehow your inch dimensions are being converted to millimeters somewhere along the way from software to Machining.
Re: size
Postby oginok » Sat Feb 09, 2019 8:02 pm
thanks, Just checked my controller to see if it is reading g-code in mm. need to get on a hardware forum to see how to toggle between mm and inches as I saw no control over that. I'm sticking with it untill I get a solution and your feedback I consider invaluable, so THANK YOU again.
oginok
Re: size
Postby oginok » Sun Feb 10, 2019 2:10 am
I was using wrong PP. IT WORKED Not the best result, but I know what to do to make better. Thanks again
oginok
Re: size
Postby mtylerfl » Sun Feb 10, 2019 4:50 am
I’m very happy to hear you got it sorted. Happy Carving!
Re: size
Postby hodad » Mon Apr 15, 2019 3:45 pm
I am having the issue of photovcarve engraving an area about .25" square when the work piece is set to run at 5"x5". The problem is not size setting for the work.
I think the problem is related to the pp. I have a shark hd4. There is no pp in the list that represents my machine. I tried to download the pp for my machine from the axiom precision site and followed the directions to the letter. Three attempts to download the pp produced no results for the pp showing up in the list. I even went as far as to reboot my computer each time just in case that is what was needed for the pp to show in list.
Frustrated with $150 program, I decided to try assigning some of the others in the list with a .tap extension. All of those that read produced same results by engraving a .25" square.
Any ideas? about to do some skeet shooting with the disk. Thank you in advance
hodad
Model of CNC Machine: CNC Shark HD4
Re: size
Postby Adrian » Mon Apr 15, 2019 5:20 pm
Where did you install the PP? PhotoVCarve is different from the other Vectric programs. It has to be installed in the Program Files/PhotoVCarve/PostP folder. You will need administrator rights to copy a file there.
If you have a Shark HD4 why use the Axiom post processors? I thought Next Wave made the Shark machines?
Re: size
Postby adze_cnc » Mon Apr 15, 2019 5:52 pm
hodad wrote:I tried to download the pp for my machine from the axiom precision site and followed the directions to the letter.
Could you post the link to the web-page were you downloaded that post-processor and where the instructions that you followed are?
adze_cnc
Re: size
Postby hodad » Mon Apr 15, 2019 6:20 pm
This is the link to the Axiom site and page that I downloaded the photovcarve pp from... https://www.axiomprecision.com/photo-vcarve.html Scroll down the page to view the instructions.
I installed in Program Files/PhotoVCarve/PostP folder. I have also copied the shark pp there as well. Both show up in the folder, but not in the photovcarve drop down list. I have closed out the program and reopened as instructed for pp to be visible in the drop down menu, but neither one is there. I rebooted computer as well and nothing is in menu.
I cannot even find a pp of any type on the Next Wave site. They sell the software for photovcarve, but I do not see any links for a pp of any sort. Unless I am not looking in the right place. Any other searches from various forums that have posted links yield page not found results. That is how I ended up on the Axiom site and thought I would attempt to install from there as one would think if Next Wave sells the photovcarve software then there would be comparability.
hodad
Re: size
Postby hodad » Mon Apr 15, 2019 6:22 pm
Additionally, The software is purchased and not a trail version
hodad
Re: size
Postby Adrian » Mon Apr 15, 2019 6:53 pm
You could try the one in this thread as I expect it would be the same as PhotoVCarve pp's are very simple - viewtopic.php?f=7&t=30140
Or any of the Shark ones for PVC from here - https://www.nextwaveautomation.com/downloads-links
Note that when you've installed the pp and you're looking for it in the list it's not the same name as the file. The name displayed comes from the name within the PP.
Re: size
Postby adze_cnc » Mon Apr 15, 2019 7:53 pm
Adrian wrote:The name displayed comes from the name within the PP.
...and that name appears to be: AXIOM HHC CNC (mm) (*.mmg)
adze_cnc
Re: size
Postby hodad » Tue Apr 16, 2019 12:38 am
That is one that I attempted to install off the Axiom site. I have been in touch with Axiom. Axiom is saying because I purchased through Next Wave, my software may be locked. That may explain why I was not granted admin rights to download from Next Wave. I am still waiting for a confirmation email for registering the software.
hodad
Next
