GBRL Post Processor
GBRL Post Processor
Postby BAC133 » Fri Feb 08, 2019 3:51 pm
Hi. I have just downloaded Photo VCarve but I note there is not a GBRL Processor. How do I go about getting this processor and how do I add it to the Processor list. Appreciate any help.
BAC133
Model of CNC Machine: Ooznest Workbee
Re: GBRL Post Processor
Postby Rcnewcomb » Sat Feb 09, 2019 2:06 am
Send your request to support@vectric.com
Postby TRosebeck » Thu Feb 14, 2019 4:13 am
I e-mailed them. Got the GBRL pp in both inches and millimeters. My problem was copying it to the list. Tried for hours but couldn’t get it. Frustrating.
TRosebeck
Model of CNC Machine: Bobscnc E4
Postby Adrian » Thu Feb 14, 2019 9:41 am
PhotoVcarve is a bit of a pain when it comes to Post Processors as it's an older program that pre-dates a lot of the security updates in Windows and Windows really doesn't like people copying files into Program Files folders these days.
Did you get it to work in the end?
Postby dah79 » Thu Feb 14, 2019 3:13 pm
Can you post the GBRL PP for PhotoVCarve? Thanks
Dave
dah79
Model of CNC Machine: FLA Saturn 4x4
Postby Mark » Fri Feb 15, 2019 12:37 pm
Hello dah79,
Please find the attached post processors.
Please copy the appropriate file to the "PostP" folder of PhotoVCarve.
This is usually located at "C\Program Files (x86)\PhotoVCarve\PostP"
(Assuming a 64 bit edition of Microsoft Windows).
Or if using a 32 bit edition of Microsoft Windows
This is usually located at "C\Program Files\PhotoVCarve\PostP"
Once you have copied the new post processor, exit the application and restart it.
The metric version of the new post processor will be labelled as "Grbl (mm) (*.gcode)"
The inch version of the new post processor will be labelled as "Grbl (inch) (*.gcode)"
in the list of post processors. Please give this a try with your machine.
I hope that this helps.
Cheers,
Mark.
Grbl_mm.pp
(4.23 KiB) Downloaded 138 times
Grbl_inch.pp
(4.23 KiB) Downloaded 130 times
Mark
Vectric Staff
Postby dah79 » Fri Feb 15, 2019 12:44 pm
Got it. Thanks Mark!
Dave
dah79
Postby darrell » Wed May 01, 2019 3:40 am
Hey
Just purchased PhotoVCarve.
Same problem with p.p.
Any help would be appreciated. I have the CWI Professor 2.3 CNC Router
Darrell
darrell
Model of CNC Machine: Professor 2.3
Postby misterx » Mon May 20, 2019 4:16 pm
I have the same problem I have photoVCarve have used it before but now have a new laptop and can't see my post processer. I have a cnc shark how am I suppose to get the processer?
misterx
Model of CNC Machine: CNC Shark Pro Plus
Postby Adrian » Mon May 20, 2019 4:42 pm
misterx wrote:I have the same problem I have photoVCarve have used it before but now have a new laptop and can't see my post processer. I have a cnc shark how am I suppose to get the processer?
The Shark post processors can be downloaded from here - https://www.nextwaveautomation.com/downloads-links
