Z-axis touch plate probe. Experiences?
Postby jaru-eri » Mon Jan 21, 2019 3:53 am
jaru-eri
Model of CNC Machine: Taig and router, Gecko G540, Mach3
Re: Z-axis touch plate probe. Experiences?
Postby Rcnewcomb » Mon Jan 21, 2019 6:09 am
That should be adequate.
Postby steve323 » Tue Jan 22, 2019 8:52 pm
I use a similar probe and it works great with Mach3. There are routines on the web for the algorithm. I modified the routine to print the amount of Z-height change. Back to back Z-height calibrations will typically be less than 0.001" on my machine.
If your spindle is grounded, then you don't need to use the red clip. Or at least I don't have to use the clip.
steve323
Model of CNC Machine: Homebuilt kit
Postby KMoffett » Mon Jan 28, 2019 1:56 am
Interesting...no indication of the height accuracy: "Size: approx. 3.5 x 2cm/ 1.38 x 0.79inch (D x H) "
Maybe I'm just used to real accuracy in height sensors.
Ken
KMoffett
Model of CNC Machine: Milltronics VKM4
Postby steve323 » Wed Jan 30, 2019 1:27 am
The height accuracy is not an issue after it is calibrated for your machine. It becomes a constant that gets subtracted during the calibration routine.
steve323
