can't open my PhotoVcarve
Postby jgstang » Sun Dec 23, 2018 12:59 am
I have not tried to open it for awhile now and today a window opened up and asked how do you want to open it ? it has always just opened... thanks
jgstang
Model of CNC Machine: iconic 2015
Re: can't open my PhotoVcarve
Postby Rcnewcomb » Sun Dec 23, 2018 1:16 am
Are you trying to open the application or are you trying to ou open a file you have saved previously?
Postby jgstang » Sun Dec 23, 2018 3:35 am
just trying to open so I can play and load a picture.... thanks
jgstang
Postby SteveNelson46 » Sun Dec 23, 2018 4:02 am
It sounds like Windows has lost the file association with PhotoVcarve. You can use the popup window to navigate to the .exe file that runs PhotoVcarve or just re-install the program.
SteveNelson46
Postby Adrian » Sun Dec 23, 2018 9:39 am
If you open it directly from the program rather than a file you should be able to load the file from there. If your shortcut is set to a file rather than the program the original program link should be on the Start Menu.
