Milling away excessive colour?
Postby jaru-eri » Sun Dec 09, 2018 2:17 pm
Have anybody tried to set the surface z-zero point to 0.2mm and that way tried to remove the excessive colour with an end mill in order to get a better result than you get with sanding?
jaru-eri
Model of CNC Machine: Taig and router, Gecko G540, Mach3
Re: Milling away excessive colour?
Postby NormanAlbert » Sun Dec 09, 2018 3:03 pm
I would think you'd get swirl tool marks that would also need to be sanded. When I spray the letter or carvings color after final overall finish coat, I take a paper towel stretched over a flat block and wipe the surface as clean as possible. Minimal sanding then required to clean the surface. I then give the job a final clear coat.
NormanAlbert
