Failed to save tool database to file
Postby hmatyas » Sun Mar 04, 2018 3:04 am
I tried adding a Ball Nose 1/16 inch to the database and I get an error saying Failed to save tool database to file C:\Program Files (x86)\PhotoVCarve\Tooldatabase\tool.tool_db
I tried to copy a new cutter and I tried new and each time I got the same error.
Thank you.
hmatyas
Model of CNC Machine: Stepcraft
Re: Failed to save tool database to file
Postby tonydude919 » Sun Mar 04, 2018 5:47 am
Did you hit apply and than ok?
Tony
tonydude919
Model of CNC Machine: cnc mako shark extended bed
Postby Jozua » Sun Mar 04, 2018 9:43 am
hmatyas wrote:I tried adding a Ball Nose 1/16 inch to the database and I get an error saying Failed to save tool database to file C:\Program Files (x86)\PhotoVCarve\Tooldatabase\tool.tool_db
I encounter exactly the same problem. It does not matter whether I “Copy” and edit or select “New” and create the tool. I get this message.
Joz
Jozua
Model of CNC Machine: EZ-Router
Postby Adrian » Sun Mar 04, 2018 10:31 am
Try running the program as an administrator. Later versions of Windows really don't like programs writing to the Program Files area.
Postby Jozua » Sun Mar 04, 2018 10:48 am
Adrian, Thank you that did the trick! :mrgreen: !
Jozua
Users browsing this forum: Google [Bot] and 3 guests
