size of carve in trial version
Postby cargo115 » Fri Sep 01, 2017 10:59 pm
Hey everyone. I have downloaded the trial version of PhotoVcarve to see if I like it. I must be doing something wrong because even though everything appears ok on the set up screen, it will only carve an image about the size of a postage stamp!! Any ideas what I might be doing wrong? Thanks, Mike
cargo115
Model of CNC Machine: piranha FX
Re: size of carve in trial version
Postby dwilli9013 » Sat Sep 02, 2017 2:10 am
sounds like you might need to switch over to inches instead of millimeters.
D-Dub
Dwayne
Dwilli
dwilli9013
Postby cargo115 » Sun Sep 03, 2017 10:06 pm
That's what it acts like but I have double checked and I have inches selected. I am baffled
cargo115
Postby mtylerfl » Mon Sep 04, 2017 12:24 am
Perhaps the Trial version won't permit carving a full size version of a file you created? You can check with support@vectric.com to find out for sure.
Did the Trial version come with sample files? If so, you should be able to carve the samples.
carvebuddy.com
Postby Adrian » Mon Sep 04, 2017 8:11 am
The trial versions will only allow you to carve the sample files. They won't save the code at all for a user created file.
It definitely sounds like a metric/imperial issue (assuming the machine has been properly calibrated to start with). Which post processor are you using when outputting the code? Is it in inches? Is your machine configured for inches?
Return to PhotoVCarve - General
