Map suggestions
Map suggestions
Postby mservis » Wed Mar 01, 2017 7:19 pm
Hi, I am making the map attached, using a 0.0625 bn bit. I am concerned that the bit is to big for the detail.
For example where there are lanes in the road the bit may eat into the lane divider.
Should I use a different bit? engraving bit?
Suggestions please.
mservis
Model of CNC Machine: Laguna Swift 4x4
Re: Map suggestions
Postby mservis » Wed Mar 01, 2017 7:23 pm
better picture of map
mservis
Re: Map suggestions
Postby NormanAlbert » Wed Mar 01, 2017 8:43 pm
Hi: Definatly use a v bit. An engraving bit of maybe 22.5 degrees and watch the depth. Try a sample portion of the map to verify you've got the proper depth. Norm
NormanAlbert
Re: Map suggestions
Postby scottp55 » Thu Mar 02, 2017 12:51 am
Maybe an Onsrud 30degree engraving, with either a .005" or .01" flat would give it to you?
Try plugging one in at 20% stepover and see how preview looks when importing/viewing at a high res.
These were done that way and just a good stiff brushing with no sanding was involved.
Didn't see how big it was, so you'll have to preview.
Scott
scottp55
Re: Map suggestions
Postby mservis » Thu Mar 02, 2017 2:28 am
Thank you Norm and Scott, the piece I am cutting will be 40 x 36 . I am going to try a sample with your recommendations. I will let you know how it works out.
Mary
mservis
