How would I define the Freud 72-300 bit for Litho?
- Model of CNC Machine: ShapeOko 2
This freud 72-300 bit is a conical (V shaped) shaped ballnose with the tip being 1/32 inch.
I want to try it for lithophane.
How woud I classify this bit as an addition to the bit menu. Its not exactly a straight ballnose, and it is not a V bit either.
Its a bit of both.
Here it is:
http://www.rockler.com/freud-72-300-tap ... -1-4-shank
K
Its a bit of both.
Here it is:
K
- IslaWW
Re: How would I define the Freud 72-300 bit for Litho?
Enter it as a tapered ballnose
GCnC Control
GCnC Control
- Xxray
I agree, tapered ballnose.
In fact a 1/32 TB is what I use for lithos, takes some time to get the fine detail but I can get details down to individual stands of hair.
Geometry of your particular bit could possibly cause variations in the cut vs a standard ballnose, only real way to tell is use both and see what is different.
I don't see any entries for a tapered ballnose.
Only Ballnose, V bits and Engraving bits.
K
K
There isn't a tapered ballnose option for PhotoVCarve. Only the more recent programs like Cut2D, VCarve and Aspire have that option.
I'd try it as a 1/32" straight ballnose as only the tip is really used so the taper should have a minimal effect.
I was going to try and import the PhotoVCarve file into VCarve desktop 8.5 but I do not see an option for tapered ballnose in the VCarve program.
K
K
It's definitely there in VCarve. Click New in the database and you can select it before entering the tool info.
- dwilli9013
You have to change it in the drop down menu on the right side of the Tool Database.kristenanne77 wrote:I was going to try and import the PhotoVCarve file into VCarve desktop 8.5 but I do not see an option for tapered ballnose in the VCarve program.
K
D-Dub
Dwayne
Dwilli
Dwayne
Dwilli
- SteveNelson46
You could just draw your own. The Freud website has detailed drawings of their bit profiles.
http://www.freudtools.com/index.php/pro ... uct/72-300
Thanks. I have added the tapered ballnose.
Unfortunately, when I imported the PhotoVCarve toolpath file into VCarve, I was unable to change the bit size that I originally used with PhotoVcarve to the new tapered ballnose bit entry in VCarve.
K
K
I never tried it as I do not own PhotoVCarve, but it makes sense to me: you import a toolpath calculated by another software, so you can't change such a fundamental parameter as the tool which requires recalculating the toolpath.kristenanne77 wrote:Unfortunately, when I imported the PhotoVCarve toolpath file into VCarve, I was unable to change the bit size that I originally used with PhotoVcarve to the new tapered ballnose bit entry in VCarve.
I assume you have the same limitations as in Aspire: moving the toolpath (and not resizing it) and changing cutting parameters (speed and feedrate). See your Vcarve reference manual or help.
HTH
Best regards
Didier
W7 - Aspire 8.517
Didier
W7 - Aspire 8.517
In PhotoVCarve, I will try creating a new "engraving bit" with a diameter of .25 inch, side angle 0f 6.2 deg, and a flat diameter of 1/32 (.03125). That should be close.
K
K
- adze_cnc
If you want to be better than just close you could use a flat length of 0.0280". Trigonometry comes to the rescue.kristenanne77 wrote:In PhotoVCarve, I will try creating a new "engraving bit" with a diameter of .25 inch, side angle 0f 6.2 deg, and a flat diameter of 1/32 (.03125). That should be close.
Steven
