Which settings for Gary Cooper in Photovcarve?
Re: Which settings for Gary Cooper in Photovcarve?
Postby FixitMike » Wed Nov 30, 2016 9:27 am
Try a small sample job on some scrap of the same material. It is the only way you will know for sure.
Myself, I have used stain, Gel stain, acrylic paint, and spray paint over shellac, and over wipe-on oil base poly. The drying times were different, the ease of application varied, but the final results have seemed the same. Only caveat is to make sure whatever you use is thoroughly dried before applying the next coat. I usually allow twice what the container says.
I prefer to apply an initial coat or three of sealer, sanded smooth, before cutting, Makes it easier to remove the excess fill color. Sometimes I even wax the surface with caranuba car wax. It gets removed when I sand the excess coloring off.
For PhotoVCarve halftone portraits, I usually use maple substrate, and dark brown stain (or paint) . A sealer after carving helps prevent bleeding.
My choice of what to use often is whichever I reach first on my paint shelf. I can't give you any information as to the life of the various options, but would suggest a final coat or 2 of a Poly finish would be a good idea. (I'm partial to Wipe-On Poly because I can apply it with a piece of paper towel, which I can just throw away after it dries.)
FixitMike
Postby mikejohn » Wed Nov 30, 2016 9:39 am
What sealer do you use? I will have to try and find an equivalent.
Mike
mikejohn
Model of CNC Machine: Shapeko
Postby FixitMike » Wed Nov 30, 2016 9:53 am
mikejohn wrote:What sealer do you use? I will have to try and find an equivalent.
Mike
I've used MinWax sanding sealer. Also MinWax Wipe-On Poly as the sealer. I would expect any sanding sealer to work.
FixitMike
Postby mikejohn » Wed Nov 30, 2016 10:00 am
Thank you :-)
I will post the results with pic.
mikejohn
Postby mikejohn » Tue Jan 03, 2017 8:41 am
I promised a picture when done.
Here is a different gary (higher res) done in Romark Mattes Engraving Laminate from Australia - https://rowmark.com.au/collections/all- ... collection
Loved the material. Works out to be the same cost per piece to make in Australia and no painting or staining.
I put the job on a a4 scanner and you can easily see the effect without standing way back.
Settings attached.
Mike
mikejohn
Previous
