Using PVC with a Laser Module
Postby rayray » Sat Nov 05, 2016 8:03 pm
Maybe a dumb question, but can PVC be used with a laser?
rayray
Model of CNC Machine: Shark Piranha
Re: Using PVC with a Laser Module
Postby GeneMpls » Sun Nov 06, 2016 6:25 pm
No- PVC turns to chlorine gas, hazardous to the optics as well as the operator. Gene
GeneMpls
Model of CNC Machine: 4x4 PRS and 3x4' 130w laser
Postby LittleGreyMan » Sun Nov 06, 2016 6:29 pm
Gene,
PVC probably stands here for PhotoVCarve…
FYI, I often read it as you did!
Best regards
LGM
W7 - Aspire 8.517
LittleGreyMan
Postby cstmwrks » Mon Nov 28, 2016 12:27 am
Everybody's most favorite answer: it depends. I use a laser with VCarvepro 8.5. Only thing it took was making a custom post processor. In my case I just use one power setting with on / off commands. Vary the amount of burn by changing the feed rate.
The depth variation to Z could feed a DAC / PWM and convert the data to power levels. I suspect that the simple way to go is just get a photo laser software. They generate g code to a spare motor axis ( mach 3 ) for power control.
cstmwrks
Model of CNC Machine: CNCRP PRO 4848
