g21 or 20. sotware makes it metrix???
Postby jerrysim » Tue Nov 01, 2016 4:17 am
hi. need some help in determining why pvc puts a g21 instead of a g20 for inches. the size obviously doesn't come out right either but the resultant image come out nice. thanks jerry
jerrysim
Model of CNC Machine: kit using vcarve pro
Re: g21 or 20. sotware makes it metrix???
Postby RhoTu » Tue Nov 01, 2016 3:37 pm
Not sure if this is your problem but check to see what post processor you are using when saving the tool path to a file. The title usually specifies 'in' or 'mm'. Also check to see if you are designing in inches or mm in the job setup.
HTH
RhoTu
Postby jerrysim » Tue Nov 01, 2016 9:36 pm
Yes. Checked for inches in all applications. Same post processer for vcp which works good. Not sure why it puts in a g21 everyone I use this software. Thanks for your response.
jerrysim
Postby ger21 » Wed Nov 02, 2016 12:24 am
Which post processor?
Gerry
ger21
Postby jerrysim » Wed Nov 02, 2016 9:03 pm
Mach3
jerrysim
