Hi everyone,
Newbie question here....... Not sure what I'm missing here but how do you save the photo v-carve toolpaths to be imported into V-Carve?
Can't seem to find one that's compatible.
Save to import into V-Carve 8
Re: Save to import into V-Carve 8
It's not the toolpaths that you import it's the .pvc file itself and then VCarve will use the toolpaths from within that itself.
http://support.vectric.com/tutorials/V8 ... C_GEN.html
- Model of CNC Machine: Inventables X-Carve 1000mm
Adrian, you came to my rescue again
Looks like the Save As option is disabled in the trial version but that was a good tutorial
Thanks!
Eric
Thanks!
Eric
You can save one of the samples that comes with PhotoVCarve and then import that if you want to try it out.
