In a general sense, what bits are others here using to produce PVC images?
Thanks Kurt
Recommendations for bits
- dhellew2
Re: Recommendations for bits
I use solid carbide 3-flute spiral ball-nose bits. The flutes and spiral help eliminate bit chatter leaving a smoother cut.
Check out http://www.cuttingtoolsource.com/ballno ... mills.html
Dale
Dale
Young = time, no money
Old = money, no time
Dale
Dale
- Model of CNC Machine: NWA Piranha Fx
Thanks for the info Dale.
Kurt
Kurt
- Model of CNC Machine: Laguna Swift With 4th axis
I use 1/8 ball nose off eBay. Ten buts for 15 bucks. Solid carbide.
http://www.ebay.com/itm/1-8-Flute-Carbi ... SwlfxXFpiG
I use a 1/4 inch 60^ v bit or an engraving bit to the the line carvings.
Bob
Bob
