PP for NWA Piranha Fx
Kurt_WI
Model of CNC Machine: NWA Piranha Fx
Post by Kurt_WI »
Just getting started with PVC. The Post Processor files for my Next Wave Automation Piranha Fx needed to be added to the software drivers which I had done. Downloaded the files, both arc and laser from the NWA site and copied them in. Upon starting the software now, I get two errors for the two drivers I just installed. The Attachment shows the error.
Thoughts? Ideas?
Thanks, Kurt
PVC Startup Error Message
stewali
Model of CNC Machine: shark
Re: PP for NWA Piranha Fx
Post by stewali »
im in the same boat as you. I have email vectric support for a postp for the piranha hopefully they will make one. U should email also. the postp you downloaded are not for the photovcarve laser. there is one for the photovcarve to user tools on the web site for the cnc sharks
Mark
Model of CNC Machine: CNC Shark, ShopBot, Roland PNC3000
Post by Mark »
Hello Kurt,
The Piranha post processors that you have downloaded from the Next Wave site
are not ones written for PhotoVCarve, I am afraid.
If you could please drop us an email to support, we can sort some out for you.
stewali,
My colleague Adam sent you some PhotoVCarve post processors for use with the CNC Shark on March 15th.
Could Adam's reply have been caught in your junk email folder?
Please drop us an email to support if you need us to resend these.
I hope that this helps.
Cheers,
Mark.
stewali
Post by stewali »
I have looked and didn't see them . I did send u another support email on may 5 or 6 could you have them reply to that one thanks for your help.
Kurt_WI
Post by Kurt_WI »
I spoke to NWA tech support via phone this past week and got some answers.
1. Use the CNC Shark post processor if using the router and bits to create the image.
2. If wanting to use the laser, you need to download the Piranha control panel and connect to the control box via USB-Printer cable if working from PVC.
The PVC file can be saved and then imported into Vcarve and used as well from that program.
I'm in the process of testing things out now.
Kurt
tonydude919
Model of CNC Machine: cnc mako shark ext bed with HD 5 gantry
Post by tonydude919 »
