Is anyone with a Piranha using photovcarve? If so, which post processor are you selecting in PVC for your machine file?
Nextwave automation does not have one posted on their download site.
Piranha post processor
- Model of CNC Machine: Piranha fx
- Bob Jr
- Model of CNC Machine: Axiom, Shark
Re: Piranha post processor
I used the Shark post processor the first time I made a litho on the Piranha using PVC. It worked fine. Now there are several different pps listed in VCarve Pro for the Piranha. When I updated the control panel software, the new post processors appeared in VCarve Pro.
Bob
Bob
"Be accurate."
W. Tell
W. Tell
When you used the shark PP, were you running on a shark CNC? I am using a Piranha. New Wave Automation told me to load their regular PP into PVC, and it results in an error message.
For the time being the only way I can move my PVC projects to the CNC is to import them into Vcarve.
PhotoVCarve is a much older program than VCarve so some of the features in a VCarve PP aren't supported by PhotoVCarve and will result in errors. Easiest thing to do is to edit the PP and remove the sections that are being flagged in the error messages.
- Bob Jr
At that time, I used the Shark post processor to operate the Piranha.
Since then Piranha post processors have been made available.
I recently used the Piranha post processor to make a 3D carving with a friends Piranha.
I also save pvc files to VCarve Pro so that I can add text to the file. I now just prefer transferring PVC files to VCP.
Bob
Bob
"Be accurate."
W. Tell
W. Tell
- Model of CNC Machine: Paranha
How do I get the shark pp from vcarve to photovcarve?
- dwilli9013
http://support.vectric.com/tutorials/V8 ... C_GEN.htmlRobert stark wrote:How do I get the shark pp from vcarve to photovcarve?
Check out this tutorial just used it the other day works like a charm.
D-Dub
Dwayne
Dwilli
Dwayne
Dwilli
