Need to change pic from portrait to landscape
drrobin
Model of CNC Machine: Handibot
Post by drrobin »
I want to import a pic that is actually a landscape pic and cut it in a 5x7. Since I own a handibot, my cutting area is 6x8... so I basically need a pic that's designed in landscape to be rotated to portrait to fit. When I rotate and save outside of PVC then import, it reverts the pic back to a landscape... anyway to rotate? And, is there any problem with the corion cutting basically a pic 'sideways' that would mess up the pic? Thanks, Robin
NormanAlbert
Re: Need to change pic from portrait to landscape
Post by NormanAlbert »
Hi: I usually rotate pictures for PVC in photo shop and save adding "rotate" after the picture title. That way I have both. Import into PVC the one you want and there you are.
drrobin
Post by drrobin »
Thanks Norman, I can do that. I just didn't know if there is a way to rotate it when you imported it into PVC. Thanks, Robin
