new to photovcarve and all
Re: new to photovcarve and all
More
- Full page photo.pdf 3.pdf
- (306.46 KiB) Downloaded 220 times
Last one give me some ideals on making them better
- Full page photo.pdf 4.pdf
- (358.4 KiB) Downloaded 215 times
- Model of CNC Machine: home built and modified Vytek rebel
Did you shellac several times before staining ? It looks like possibly the stain may have penetrated fairly deep and you had to sand to much off to see the contrast. The first several I did, I did not seal with shellac first and only stained them and mine came out looking very much like yours. Another thing I have done is in stead of using stain I use a very fast drying spray paint and apply that after the shellac process. What percentage line spacing are you using and what angle cutter ?
Actually it looks like you off to a pretty good start and only need some tweaking on the finishing process.
I am enclose a picture of the second one I did that came out fairly well but there were 3 before this one that were horribly bad. You can see where I sanded off to much in some areas because I did not seal it first and only used stain,You can also see where the stain bleed in so deep ( if you zoom in) that it removed the contrast.
I also did a lot of photo editing in Gimp to get these results. The quality of the original picture was from a low meg pixel camera and things like his nose were not in the picture, so I actually darken his nose and goatee in Gimp so they would show.
I just looked at the last 2 pictures you posted, and the suggestions I have been giving you do not really apply to the type of picture in the last 2. I think that there are some threads on here that can help you immensely though. This thread in the gallery section ( 4 one down ) has what you need.
These are my pictures in wood
12345Attachment(s) by WoodArt » Fri May 18, 2012 4:02 pm
Thank for feedback. All pictures are of same thing just different setting bits and stain color. I like the smooth look I can make but want the detail I get in the one that shows lines.. On the dark one I used a spray sealer that didnt do as good as the brush type. Have two more change I want to try before I go back to the one with lines in it to try and make them smaller.
Ps I have read yoyr other post.. you use paint?
The clock is one I used a fast drying paint on after I put shellac on it and I like that finish a lot. I also did one of my grand daughters I did where I used a black stove hand rubbed finish on it, but I had a problem with it bleeding in to the wood grain even after shellacking.
So far I am the happiest with a fast drying spray paint.
Well I tried paint didnt come out good. Thing im going to try some gel stain or something..wipe it on let it sit and wipe it off and see how that comes out.
Don't let it sit.wipe it on let it sit and wipe it off
Wipe on-Wipe off.
You can always do it again if it needs to be darker.
latest try
- (172.87 KiB) Downloaded 537 times
So anyone have any ideals to get it better
- Ms Wolffie
I am not an expert on PVC
To me it looks good but why oh why did you cut the top off the poor baby's head?
Make sure you get the complete photo and leave a space around, otherwise the end result looks wrong.
Be careful with the figure in the wood, it can make or break a picture.
The less figure the better.
Cheers
Wolffie
Whatshammacallit
Wolffie
Whatshammacallit
