First Lithophane with PhotoVCarve
Image below was cut into corian 1/8 inch thick 4inches wide 5 inches high. .047 ball end cutter. Cut speed was 50 ipm. Took about 1 hr to finish. Very impressive. Picture of litho not back lit did not come out so well but the others show how good it is.
- (19.04 KiB) Downloaded 759 times
- (20.27 KiB) Downloaded 751 times
- (11.16 KiB) Downloaded 4121 times
I got the corian from ebay. Sink cutouts! The stuff I got was 1/2" thick so I cut it into 4.5"strips and then split the thickness down to 1/8" on my table saw. I had to stay with 4.5" strips because that's the max I can split them on the saw. The picture looks even better live. The picture of the litho doesn't really show how good it is. This PhotoVCarve software is great.
First attempt with cast acrylic...4x6 with the same lightbox as above. Cut very clean and easy. Material is 1/8" thick and I only cut to a depth of .08. I think I should have gone to .1 and it would have come out brighter.
- (10.91 KiB) Downloaded 3787 times
- dighsx
What colour was the cast acrylic you used. I've got some coloured laying around but it's pretty dark. Wasn't sure if it would work or not.
Take it easy.
Jay (www.cncjay.com)
I am just using a push in light socket with a nightlight bulb (4watts). The picture size is only a 4"x6" and the light seems to work out very well (no hotspots and even and very little heat). I would think a 5"x7" picture would work well with this setup also. I haven't tried it yet but I will soon. I did use a 7.5 watt bulb also but it seems to give more of a hotspot effect in the center. Also of note, the bulb I am using is clear not a frosted white.For some reason when I tried a normal white bulb I get more of a hotspot also. Hope this helps.
I got my first Lithophane cut last weekend. It turned out better than expected. I managed to get it cut out and did not even break a bit. Thanks for all the great information and tips. I am currently experimenting with the backlighting. The litho that I cut was a 16" x 13" oval in corian. I figured why start out small? If I am going to waste a perfectly good piece of corian then I might as well waste all of it? I have many ideas for lighting this, but am currently waiting shipping of supplies to get this on the test bench. Will let you know how it goes?
Has anyone else messed with this large of a lithophane and the backlighting? I am just trying to get a good starting point on depth of box and all.
- Model of CNC Machine: Flexicam, ShopBot Buddy BT48,Vision 2448
Hi dman,
I have access to Avonite which seems to be the same as Corian. It is 1/8th inch also. I use ArtCam and am looking to buy VCarve as it does things ArtCam doesn't.
I tried lithophanes with the Avonite - 3"x4" as these were the samples I had. I had to route down to
.03" to make a lithophane appear OK - but the material got quite thin. I have seen many people use .250"
material and leave a .03" base - then make the Z height about .1". What is the Z height that you use? Are yours quite thin also when you're done?
I just downloaded the trial version of PhotoVCarve and will give it a try soon also.
Tom
Tom
Tom,
On my lithophanes, I use a cut depth of .08" or .1" - (white areas will be cut to this depth). Yes the white areas are quite thin when finished but the black areas are .125"or close to it. I think it has to be this thin in the white areas to allow the light to pass through and showup bright white. PhotoVcarve is very easy to setup for the lithophanes using 1/8" material or any other thickness. It is a very user friendly. After you play around with it for a while you'll like it very much I believe. Let me know if I can help anytime. Below is another example of a litho I did. Picture on the left is the original black and white scanned picture and the one to the right is the litho in the lightbox. I need to get a better digital camera as the litho comes out much brighter and with more contrast than it appears in the photos.
Damian
Damian
- (37.01 KiB) Downloaded 684 times
