A newbies journey into Photo v carve.
- Model of CNC Machine: Industrial CNC
Hello I've been a carpenter my whole life. But I'm very new to the cnc world. I'm going to start this thread to document my journey. And hopefully help people along the way.
My first attempt was a photo of a tiger. . I used a 60 degree v carve bit. Here are my pitiful results. . So after some research I switched to a 7.5 degree engraving bit. With a .065 tip. I was hoping this would get rid of the lines. My only problem was the bit tip was to small to match the line spacing. But I tried anyway. . Much better results, but still left lines. So I have decided to order a different bit. Going to go with a carving bit but with a larger tip to help match the lines spacing.
So I thought I knew what I was doing so I tried a pic of my daughter. With the carving bit, trying to match the line spacing to my bit tip. Horrible results. I played with the depth quite a bit but could not get the detail and better. I'm hoping a better bit with a slightly larger tip and less of an angle will help. I will order one tomorrow, and post my new finding in a few days.
In my research I've come up with a very newbie question. When people call for an overlap of say 35% when setting up a tool path what do they mean by this?
Re: A newbies journey into Photo v carve.
Try removing the background in the photos first and then proceed with your bit test. You'll have more contrast and take less time to carve.
Can anyone explain or offer help in what is meant when people adjust overlay?
Have you looked at the tutorials on http://support.vectric.com/training-mat ... hotovcarve and did you look at the help contents in photo vcarve program? Look at the following attachments. I use a 10 % stepover most of the time.
Tony
Tony
Very helpful Ty. And yes I do look at and read the tutorials. I just overwhelm myself with info. So much to learn. So much to do. I'm very excited, I can't sleep at night. I want to make everything.
I have never used Photo shop, but my wife owns Microsoft word. This part of the program seems to remove backgrounds very easy.
http://office.microsoft.com/en-us/word- ... 55182.aspx
Try number three. 35% step over instead of 120%. The bright back ground had a huge effect on the detail in this one.
Slow and steady wins the race. I do have a "control" picture I'm working with I just wanted to try this one.
Not much interaction or help on this forum. Can anyone recommend a forum where people actually reply or comment on posts? Does Shark have a good forum?
- Vectric Staff
- Model of CNC Machine: Saimsmart CNC
Hi Creative,
You seem to be making good progress.
What do you need assistance with?
- Model of CNC Machine: shopbot buddy bt 32
hello looks like your coming along well. Not alot of info out there on doing this on wood . I do tons of lithos and i'am getting ready for my first one on wood I need to do a memorial plaque for a family member . Xray sent me to a thread that goes to the best wood lithos I've ever seen. But the man doesnt get on the forum anymore you can see it mine is the next post down asking for help with lithos on wood under POPS1964. I hope you'll answer a question for me I'll be starting this week with my attemps and maybe we can help each other along. What are you doing for a finish to fill in the shadow lines thanks and good luck . pops
POPS1964
SHOPBOT Buddy BT-32
SHOPBOT Buddy BT-32
For the finish I use flat black spray paint. then lightly sand. Boot polish works well too. Wipe it on, the clean it off the surface.pops1964 wrote:hello looks like your coming along well. Not alot of info out there on doing this on wood . I do tons of lithos and i'am getting ready for my first one on wood I need to do a memorial plaque for a family member . Xray sent me to a thread that goes to the best wood lithos I've ever seen. But the man doesnt get on the forum anymore you can see it mine is the next post down asking for help with lithos on wood under POPS1964. I hope you'll answer a question for me I'll be starting this week with my attemps and maybe we can help each other along. What are you doing for a finish to fill in the shadow lines thanks and good luck . pops
