How to machine Lithophanes with PhotoVCarve
The Lithophane shown below has been machined into a piece of Avonite (similar to Corian) using PhotoVCarve.
Lithophanes are photographs machined into translucent materials such as Avonite, Corian, Plexiglass, Perspex that when back lit turn into photo-realistic images as shown below.
Each of the designs below are 8" x 6" and cut into 1/4" material, and took approx. 4 hours to machine at 1" / sec.
A roughing toolpath was calculated for a 1/8" dia ball nose cutter to remove the excess material. Followed by a finishing toolpath for a 0.04" dia ball nose cutter that machined the full detail leaving around 0.04" on the botom face of the material.
The process is explained in the attached PDF file.
The Roughing toolpath is not needed when cutting material thinner than around 1/8" / 3mm.
Important - The Z0 origin is set at a different height into the material for each toolpath and the diagram below tries to show this.
Please read the PDF file and ensure you understand how to setup the toolpaths before running your machine!!
Let us know if you have any questions about cutting Lithophanes.
Tony
Tony
- Machining_Lithophanes.zip
- Getting Started Manual PDF
- (2.31 MiB) Downloaded 1141 times
- Finished Lithophane - Looks fantastic!
- (75.6 KiB) Downloaded 1378 times
- 3D Lithophane on the machine
- (107.45 KiB) Downloaded 1198 times
- 3D Machine - Cose-up
- (57.79 KiB) Downloaded 1164 times
- 3D Machined surface without lighting
- (73.8 KiB) Downloaded 1329 times
The Video Tutorial below explains how to use PhotoVCarve for making Lithophanes
Video Tutorial
Here's a short video showing how the 3D lithophane turns into a photo-realistic image when back lit.
Video clip
Tony
Video Tutorial
Video clip
Tony
Hi Paul,
I'll try and find some suppliers.
You can also use Conical Tip Radius Cutters such as the one in the picture below.
Calculate the toolpath for the Ball nose but cut using the Conical Cutter.
There will be a very slight overcut but not noticeable in the actual piece.
Tony
Tony
- Conical Tip Radiussed Engraving Cutter
- (46.81 KiB) Downloaded 1072 times
- Model of CNC Machine: ShopBot PRS Alpha
Suppot video
Tony,
Can't find the supporting video that is mentioned on page 3 of the PDF tutorial. Can you help?
Bill
Bill
Hi Bill,
The link to the Video Tutorial was missing so I've also included in my 2nd post above.
Let us know if you have any additional questions.
Tony
Tony
lithophane video
Hi Tony can you put up a video of the tutorial and the lighting that I can download and play at my liesure?
thanks Bob
thanks Bob
Hi Bob,
The zipped files can be downloaded from,
Download the Video Tutorial
Download the Video clip
Have Fun,
Tony
Have Fun,
Tony
Litho structure
Tony,
While we're at it, can you run through the procedures you used to get the two photos positioned in frames with profiles and side by side?
Bill
Bill
