What have you all found to be the best material for making lithographs. I have tried a few in 1/4" HDPE plastic, and they are ok, but not great. Is 1/8" material better? I live in the USA, so where do you buy from? www.usplastics.com? Any help is appreciated, thanks!
Mike
Best material for lithographs?
- ssflyer
- Model of CNC Machine: ShopBot PRSAlpha 96x60
Re: Best material for lithographs?
Hi Mike,
If you mean lithophanes, then I make mine out of Corian, a solid surface material. I get most of mine off E-Bay, but local cabinet/countertop shops may have off-falls that you can get cheap or free. I usually make mine out of 1/4" material, but you can always surface it to whatever thickness you like. Biggest difference in quality comes from a high resolution image, setting up the component height and minimum thickness for proper translucency, and I usually finish mine with a 1/16" ball nose bit.
I'll try to find a couple of tutorials other have done that outline the procedure very well.
Oops - just noticed this is in the PhotoVCarve section. I use Aspire, but THIS thread might be a good start for you to check out.
Ron Sloan
I use 1/4" corian. I buy mine on eBay.
Tony
Tony
- Model of CNC Machine: CAMaster 508 ATC + Rotary
Here are two lithophanes I did a while back using 1/4 Corian
http://forum.vectric.com/viewtopic.php? ... 13#p109513
Mick Martin
Aspire 4.015
http://mickmartinwoodworking.com/
Aspire 4.015
