3D Grayscale Machining in PhotoVCarve
Postby ChrisInEstes » Tue Oct 01, 2013 11:46 pm
I've had PhotoVCarve for quite a while... just never used it. I was looking at the features of it, and see where it's supposed to do 3D Grayscale Machining with a ball bit. How do I get that to work? I looked at the videos and didn't see anything about it. Am I missing an update, 'cause I don't see anything in the software that says anything about it.
Chris
Aspire 8.5 - PhotoVCarve - FlexiEXPERT 11
ChrisInEstes
Re: 3D Grayscale Machining in PhotoVCarve
Postby Adrian » Wed Oct 02, 2013 8:35 am
Here's a couple of threads that should get you going.
viewtopic.php?f=2&t=2192
viewtopic.php?t=536
Postby Sara M » Wed Oct 02, 2013 12:10 pm
Dear Chris,
Please consider attached a PDF document that covers an example of how to set up a toolpath for 3D Grayscale machining in PhotoVCarve.
I hope that this helps.
Best regards.
PhotoVCarve_3DGrayscale machining.pdf
(538.43 KiB) Downloaded 934 times
Sara M
Model of CNC Machine: jjgjgjg
Postby ChrisInEstes » Wed Oct 02, 2013 11:19 pm
Thanks Adrian and Sara! I see how that works, and now I can experiment.
Chris
ChrisInEstes
Postby PaulRowntree » Wed Oct 02, 2013 11:39 pm
Sara's writeup (thank you!) should be put into the Technical Archive section (as PaulZ's inlay paper is) for future reference.
Paul Rowntree
PaulRowntree
Postby huntleybill » Thu Jun 01, 2017 4:02 pm
That PDF is great but the picture I am using is not in gray scale. So are you saying that converting the picture to greyscale will do the trick?
So then my next question is, How do I convet the picture to greyscale?
huntleybill
Model of CNC Machine: Home Built
Postby Adrian » Thu Jun 01, 2017 5:03 pm
Depends on the picture. It's not a technique that will work with a photograph of animal or a human without a great deal of effort but that's true of even Aspire.
Both these links have posts that talk about the formatting of the pictures:
viewtopic.php?t=536
Postby Bobtail Farm » Tue Jan 16, 2018 4:33 pm
Thank you all for the pointers.
Bobtail Farm
Return to PhotoVCarve - General
