Image load problem
- Model of CNC Machine: Legacy Arty 58
Image load problem
I've used PhotoVCarve a number of times, mostly for lithophanes. A few days ago I worked on a new design, but then when I went back to change it, all I could get is a black rectangle where my image had been. Since then every time I try to load any jpg, I get the same thing. From a split second glimpse I got at one point I think the image is there, but the black box overlays it. Has anyone else had this problem or knows of a solution?
Re: Image load problem
OK, this was odd. I opened the image I was trying to use in a photo editing program. After messing around for awhile and then discarding my changes, PhotoVCarve opened it as it is supposed to do. No idea why that made a difference, but it's working. BTW, even when I couldn't see the image, PhotoVCarve would still do the preview.
- Ms Wolffie
I think you have a gremlin in your computer
Cheers
Wolffie
Cheers
Wolffie
Cheers
Wolffie
Whatshammacallit
Wolffie
Whatshammacallit
Dear Stickman,
I have replied to your email sent to support regarding the issue seen on PhotoVCarve.
Possibly, it will help explain the event.
Best regards,
Sara.
Best regards,
Sara.
I suspect the issue was the size of the image file I was trying to use. When I found a larger version, it opened up ok. Regardless, the preview of the toolpath showed up as expected even when I couldn't view the jpg.
