Downloaded the trial and had a go. I had one problem in that the "make Clour Transparent" option I could only seem to remove one colour, is this a limitation with the trial or is it a limitation in the full as well? or more likely am I doing something wrong?
Anyway heres a pic of the Buzzard I had when I was a young lad, its carved into 5083 Alu and size is 160mm x 132mm
It took about 30mins to alter in a graphics program and go through the steps in PhotoVcarve then only took 12mins to machine and probably about the same to clean up the paint (next time I will mask a bit round the edges to make things quicker. Also next time I will make the lines closer so that the detail stands out even more. Think I will be purchasing this program very soon
Hood
