Problem with VCarve Pro Software?
Postby xiguatou » Sun Feb 03, 2013 12:57 am
Today I tried to work with mu VCarve Pro ver 6.503. The program has been working fine, yet today I experienced some problem.
When the program is open and I try to click on any of the Menu buttons, the program closes! If i push FILE, GADGETS or HELP, the results are the same---the program shuts down.
Any advise would be welcome.
Thank you
Slicric
xiguatou
Model of CNC Machine: cnc shark pro
Re: PROBLEM WITH VCarve Pro Software?
Postby Leo » Sun Feb 03, 2013 1:04 am
Reboot computer and try again
www.leosworkshop.com
Leo
Postby xiguatou » Sun Feb 03, 2013 1:11 am
I have done the reboot things 2 times now
Slicric
xiguatou
Postby Bob Reda » Sun Feb 03, 2013 2:03 am
Just went through that. It is something to do with your anti virus software. In my case it was the Constant Guard that comes with comcast norton. I just shut it off and it worked fine. Must of been in one of their upgrades.
Bob
Bob Reda
Postby xiguatou » Sun Feb 03, 2013 2:09 am
Interesting, I also have the Comcast anti virus. I will go try that now.
Thanks for the input. Will get back to you
Slicric
xiguatou
Postby xiguatou » Sun Feb 03, 2013 2:43 am
Bob, it did not work. I have the program loaded on my desk top in the house and it is working fine. You think I can take the VCarve file folder and copy it to my laptop?
Slicric
xiguatou
Postby signmarketingman » Sun Feb 03, 2013 2:50 am
norton is notorious for causing pain on PC computers.. You have to remove it completely 100% to rid a machine of its problems. Some have to download the norton cleaner from norton site to get it all.
signmarketingman
Model of CNC Machine: Professional done home built.
Postby jimwill2 » Sun Feb 03, 2013 3:01 am
I have been using Norton without issue for several years. Are you having trouble with VCP on a second computer? You can run it on multiple computers but you need to contact Vectric to get the install code. It won't work unless you get a new code.
Jim Williams
"If it was easy anybody could do it!"
http://expressionsofhonor.com
jimwill2
Model of CNC Machine: CaMaster Stinger w/recoil, FTC
Postby Bob Reda » Sun Feb 03, 2013 3:07 am
I had just started experiencing that problem recently and have norton on my pc for several years. I just happened to see a dialog box pop up saying it (aspire for me) was unsafe and it shut it down. Same thing, any menu button would shut it down. I just shut off the constant guard and it worked fine. I guess I could have added it to the safe program list also.
Bob
Bob Reda
Postby David Warkentin » Sun Feb 03, 2013 3:46 am
I added Vcarve Pro to another computer without any special code except the original one....
David Warkentin
Model of CNC Machine: Camaster Panther 4x8
Postby xiguatou » Sun Feb 03, 2013 4:51 pm
I have VCP on another computer and it is running fine. It also has the Comcast software on it. Not sure what do do. Cannot find VCP program disc so will contact Vectric. Bob, I turned off the norton to no avail so think I should reload the software. Your thoughts?
Slicric
xiguatou
Postby Bob Reda » Sun Feb 03, 2013 5:10 pm
I did that, but make sure you backup all your files first and your tools. It won't hurt, you can get all the uopdates at Vectric. However, if it has been running fine for all this time, I think it would be something with the computer. Also, I don't know if you ever heard of the Letterheads, but a microsoft update did something to their stuff and Microsoft had to send out a patch to fix it. I talked with Mark at Vectric about this but he didn't think that would have anything to do with it. I would report this to Mark just so if it starts happening to others he will have a leg up. He will also help you with your problem, it that regard, as long as you have one running don't do anything until you talk with Mark. He'll try and help you through it. I guess re installing is the last resort as I think about it.
Bob
Bob Reda
Re: Problem with VCarve Pro Software?
Postby signmarketingman » Sun Feb 03, 2013 6:25 pm
The microsoft update affected only fonts.
signmarketingman
Postby xiguatou » Tue Feb 05, 2013 4:07 am
I got an email from Mark today and he mentioned that many people have similar problems and all have Comcast Norton Security Suite Constant Guard. He mentioned a possible Safe File might have a 'hold' on my program. I looked but could not find anything that might help, but I am not a computer guru.
I looked in the Comcast program in the Monthly Report and listed 2 files between the time I last turned the laptop on, the files names I did not recognize.
I have the program on my home computer -its a desk type so not easy to move into shop. Anyway, it is used almost daily with the same Comcast thing, and the VCP works good on it. I use the laptop about once a week and it is the one that gives up---go figure!
Just thought I would keep you posted. Any ideas?
Later
Slicric
xiguatou
Postby xiguatou » Tue Feb 05, 2013 4:16 am
I forgot to mention, I downloaded the VCP trial version, and it did the same thing---closed when I clicked on a menu button.
Slicric
xiguatou
Next
