Hi all
Here are a couple of pictures cut in Aluminium (6082)
Both plates are 90 x 90 x 3mm and were cut using a 60Deg Inc bit at 0.3mm max depth.
Matt black paint was used to bring out the detail.
First cuts with PhotoVCarve
- (65.88 KiB) Downloaded 1644 times
- (97.81 KiB) Downloaded 1768 times
After machining, Scotchbright was gently rubbed along the cut lines to remove the small burrs left by the cutter then washed and dried before applying the matt spray paint. Once dry I used fine emery cloth to remove the paint and apply a grained finish vertically, followed by fine Scotchbright (maroon) to finish.
Actually this was the second attempt, I first used black felt tip pen which was not a great success. I found that the sides of the small V shaped cuts were not fully covered which detracted from the overall effect.
Thanks for your comments by the way.
Andrew
Andrew
Cutter used;What type/brand of vbit are you using. Do you have a link to an online source?
Ø3mm x 60Deg Inclusive. Single flute carbide. 0.2mm Tip.
When I cut these I only had one engraving cutter to choose from! I bought it a few years ago from a company called Mastergrave here in England.
http://www.mastergrave.co.uk/home/default.php
Unfortunately, I can't find the cutters on their web site so I did a quick search and found a good description here;
http://www.antaresinc.net/FactCutterGeometry.html
and a possible source your side of the pond;
http://www.gravograph.com/usa/Engraving ... utters.php
Thats right, no power tools used for finishing. The plates are only 90mm square and were unmarked before starting so they only took 3 or 4 minutes each to finish max.Sounds like it was all hand finishing(no power tools)
Andrew
