Background removal in PhotoVCarve
Postby ErnieD » Mon Jan 31, 2011 2:52 am
I am a new user of PVC and I am having a tough time getting set up. I am trying to use a picture of my granddaughter and make a lithograph in wood and or aluminum. I am trying to remove all the background and cannot make any headway.
I have tried to remove the background using PaintShopPro and PhotoShop, both of which I find difficult to use. I think mostly because I am old, impatient and crotchety.
Have been to some forums and have been asked to post a picture of my granddaughter so that they could help but I have declined as my wife does not think that the picture should be posted in a public forum.
Short ob purchasing the required books for the above mentioned pieces of software,
can anyone come up with clear, concise and easily understood directions for background removal. Something that only requires one or two key strokes or mouse clicks would be nice.
Ernie
ErnieD
Re: Background removal in PhotoVCarve
Postby Cdat » Mon Jan 31, 2011 3:12 am
Look up the search function on this forum and type in REMOVE BACKGROUND. It ain't magic and will not work with a mouse click or two when you find the answer you're looking for. I'd tell you myself but I'm grumpier then you and figure you need to do it yourself. :twisted:
When I want your opinion, I will give it to you.
Cdat
Postby ErnieD » Mon Jan 31, 2011 3:47 am
Hi Cdat,
Thanks for the reply. I did the search and found that I must edit the photo with another software to remove the background and then import it into PVC. I guess I will look around for a deal on one of those.
Ernie
ErnieD
Postby P.Passuello » Mon Jan 31, 2011 4:34 am
Check out Gimp. It is free and will do the job for you
http://www.gimp.org/
Cheers
Peter
The ingenuity of idiots is unlimited.
http://www.youtube.com/user/cncnutz
P.Passuello
Model of CNC Machine: Joe's Hybrid
Postby sawmiller » Wed Feb 02, 2011 10:25 pm
here's one i did....
Using gimp to photo edit for photocarve.pdf
(950.44 KiB) Downloaded 3914 times
In the heart of Tn
sawmiller
Model of CNC Machine: joe's rack and pinion hybrid
Postby jhedlund58 » Sat Feb 05, 2011 1:31 pm
I am old, impatient and crotchety and wood like to thank sawmiller for his pdf document on gimp.... my sweet, patient and saint of a wife got me gimp last week and i have been trying 2 get the background removed as well. sawmiller's instructions are great...... i recommend the walgreens 1.5x cheater glasses as well..... just hang em off the nose a little and growl whenever a kid comes close..... u should b OK.
jhedlund58
Postby BrianM » Sat Feb 05, 2011 7:25 pm
sawmiller wrote:here's one i did....
Hi Dan,
Thank you for creating and posting this guide - I've made it sticky on the PhotoVCarve forum.
Brian
Brian Moran
Chairman
Vectric Ltd.
BrianM
Vectric Staff
Postby sawmiller » Sat Feb 05, 2011 8:14 pm
:oops: your welcome
In the heart of Tn
sawmiller
Postby ErnieD » Sat Feb 26, 2011 5:15 pm
Sawmiller,
Talk about clear, concise and detailed! I like it. I have not had the time to try your instructions but I will soon.
I thank you for this great posting.
Ernie :lol:
ErnieD
Postby patmcl » Tue May 31, 2011 6:48 pm
I can not get the Gimp to work for me. Every time I click the whole selection button the whole image FG and BG turn the same color. It is as if the invert is not doing its job or my selection around the whole image is not completed. It looks like the starting and finishing do not join up even though I try to get them to join. Can anyone offer any suggestions. Pat
Learning by trial and error or with the help of others is still learning and a great addiction!
patmcl
Model of CNC Machine: shop bot
Postby jhedlund58 » Tue May 31, 2011 8:34 pm
I had the same problem with gimp... but after the high school kids showed me a couple of times it does work.... the problem 2 me... is one wrong mouse click and u have 2 start over.... find some kids who r used 2 old men....... also... i find.... if i cut the lawn they will do the editing.... trade-off's!!! walgreen's cheater's r a must
jhedlund58
Postby sawmiller » Wed Jun 01, 2011 11:24 am
pat
might be you are missing one step
Then select "selection from path" using the using the select menu or button on the path menu .( under the second picture in the tutorial)
it doesnt even matter if the path is alll the way closed, it will draw a straight line between the endpoints
your selection will be dotted. then you invert
hope this helps
dan
In the heart of Tn
sawmiller
Postby patmcl » Wed Jun 01, 2011 12:06 pm
Thanks Dan, I have tried this over and over and still no luck. I get the conecting lines all around my image, so I am lost it appears the invert is working. Pat
patmcl
Postby sawmiller » Wed Jun 01, 2011 12:32 pm
try it with a new image
start up gimp, goto file menu and select new
it's easier to see if you have older eyes like me, helps to see just how it's working
once you have selected a area try fill with foreground
again good way to see it, white on black
In the heart of Tn
sawmiller
Postby edokus » Thu Aug 25, 2011 4:08 pm
:D
Great suggestion RE: GIMP. I had a little trouble obtaining the required result in removing the background but ultimately suceeded with great results.
edokus
Model of CNC Machine: Shark pro
Next
