Light box for lithophane
Postby michael307 » Sat Jan 08, 2011 6:52 pm
I need a source for back light boxes for 5x7 and 8x10 lithophanes I make. I have tried many different homemade frames with limited success. I am looking for an inexpensive source for back lighting. I am cutting many lithophanes and need the backlighting out of the way. I do not really want to make them myself, liability and not that good at it. Any suggestion will be appreciated. :lol:
PhotoVCarve
VCarvePro v8
VectorArt3d
Servo Driven 12X24 router
Plasmacam 4x4
michael307
Re: Light box for lithophane
Postby ssflyer » Sat Jan 08, 2011 11:57 pm
I've used these before - backlit photo frame. They have a larger one, also. I simply cut out a piece of verneer for placing the litho.
http://shopping.netsuite.com/s.nl/c.ACC ... /id.883/.f
They aren't bad, and they're cheap!
Ron
Ron Sloan
ssflyer
Model of CNC Machine: ShopBot PRSAlpha 96x60
Postby fixtureman » Sun Jan 09, 2011 5:02 pm
I use the flexible led strip lights. I get them from from this seller.
http://shop.ebay.com/dreamcolourlightin ... ksid=p3686
I ordered the wall warts from this place
http://www.tti-plus.com/12VDC-500-mA-Pl ... nextag.com
and the plugs from here.
http://www.bgmicro.com/21mmjacksandplugs.aspx
fixtureman
Postby michael307 » Sun Jan 09, 2011 7:41 pm
Just how much space is there light to the litho? Are the lights right on the surface of the litho? For a 3x3 litho for a night night I am using a flat 3x3 led night light from Walmart and double face taping it directly to the light.
PhotoVCarve
VCarvePro v8
VectorArt3d
Plasmacam 4x4
michael307
Postby fixtureman » Sun Jan 09, 2011 10:39 pm
The box that is in my picture is 8 X 10 X 2.5 the leds are only on towards the back and just one strip of 12 leds the top and 1 strip of 12 leds on the bottom. A coil of Leds that I show will make about 25 lithos.
fixtureman
Postby MikeUSNRet » Mon Jan 10, 2011 7:18 pm
On the lithos I have done, i have just made a simple box for them.
.75 thick stock approx 2" wide.
cut a 1/8" channel aprox 1/4" back from the front side, and a 1/4" wide x 1/4" deep rabbet along the back edge.
Measured the sided and cut the strip to length with mitered corners. Installed the litho in the channel then glued and clamped the frame together.
Measured and cut 2 led strips to fit into the top and bottom of the frame, wired them up and then hot glued them into position.
set a piece of 1/4" thick hardboard into the back and called it good. In the backerboard, I have also cut a keyhole into the top that way the frame can either be placed on a table or hung on a wall.
Mike
STGC(SW/AW) M. Wenman USN Ret.
1982 - 2005
MikeUSNRet
Postby fixtureman » Mon Jan 10, 2011 11:18 pm
I do paint the inside white and I use a piece of white 6 mm sintra for the back.
fixtureman
Postby olf20 » Tue Jan 11, 2011 1:52 am
Here is another place to get LED's and power supplies.
Over on the Saw Mill Creek forum they have a small write up.
http://www.sawmillcreek.org/showthread. ... leds-signs
olf20 / Bob
olf20
Postby ScopeGuard » Wed Jan 12, 2011 4:10 am
I've used this on lithos. Simply apply to the entire surface. Best I recall it was about $30 and the guy sent the initial piece pre-wired to show me how it is done. Instructions are on his website/Good product, you can run it off batteries, add an on/off switch. You can get battery holder and switch at Radio Shack.
http://world-electroluminescent.com/new ... ducts.html
Regards,
Don
Don
Techno LC4896
NextEngine 3D Laser Scanner
Conoscope Laser Scanner
http://www.proscan3d.com
ScopeGuard
Model of CNC Machine: Techno LC4896
Postby cdavies » Wed Feb 21, 2018 2:17 am
I just started making lithophanes with supplies from thecandlestonestore.com I also am looking for an easy way to light my end product. Anyone else have ideas. I don't like making my own boxes and would prefer a frame the stone would just fit into. They have some on their web site but they are always sold out. Chris
cdavies
Model of CNC Machine: cnc shark
Postby Xxray » Wed Feb 21, 2018 10:59 pm
Been doing lithos for years, have yet to find anything close that would fit the bill.
If you did, you would likely go into sticker shock.
I make my own because I use various sizes and also fairly cheap, probably less than $10 in parts. Its all in the labor, once you get a system down they go pretty quick.
Doug
Xxray
Postby tonydude919 » Fri Feb 23, 2018 3:34 am
Here is my light box I just did recently. Been doing these for years.
Tony
with led light off
With the led light on
tonydude919
Model of CNC Machine: cnc mako shark extended bed
