G code error
G code error
Postby hfwiley » Wed Jul 17, 2019 11:50 am
Hello All.. I am running UGS platform on a E4 Bobs cnc, I keep getting an invalide G code error when trying to run the cut. I have tried with different photos and settings with in PVC, any one know what G code commands are supposed be at beginning of program or have any ideas.
hfwiley
Model of CNC Machine: bobs cnc e4
Re: G code error
Postby Adrian » Wed Jul 17, 2019 12:04 pm
Which post processor are you using? Is it the correct one for your control software? Does the company that make it have a post processor on their support pages?
Re: G code error
Postby hfwiley » Wed Jul 17, 2019 2:52 pm
It is GRBL, and it may be that it is writing a tool change command that it doesn’t recognize.. will try eliminating that from code.
hfwiley
Re: G code error
Postby Leo » Wed Jul 17, 2019 3:53 pm
Are you using a post processor with ATC or one without ATC. You should not be using the one with ATC -- IF -- that is the problem code.
www.leosworkshop.com
Leo
Re: G code error
Postby hfwiley » Wed Jul 17, 2019 5:17 pm
The T1 command in the G code was the issue, once I eliminated the tool change command it started the cut. GBRL doesn’t support tool changes so the first command was incompatable and threw the code.
hfwiley
Re: G code error
Postby Adrian » Wed Jul 17, 2019 5:30 pm
You can download the grbl post processor from here - https://forum.vectric.com/viewtopic.php ... 13#p209813
It sounds like you're using the generic g-code one.
Return to PhotoVCarve - General
