Box Creator Mods
This forum has been created for users to submit suggestions for Gadgets
Box Creator Mods
Postby leversole » Thu Dec 12, 2019 1:19 am
Would like a small change in the box creator, may be simple...I have looked through the code and cannot find the right spot...
What I would like is to suppress the small "tails" where the router bit sets clearance for the sharp corners of the dovetails...I use a very small bit and through testing, I do not need these...I have been going through and node editing the tool paths to get rid of these, very time consuming!
I am hoping that these are done with a fucntion call that I can supress, or a series of lines in a function I can rem out...If someone can point me the section of code that creates these I would be most appreciative
Leslie
leversole
Model of CNC Machine: OX Type
Re: Box Creator Mods
Postby leversole » Thu Dec 12, 2019 6:54 pm
Maybe not the correct way...but it worked...
leversole
Postby jimandi5000 » Sun Dec 15, 2019 11:37 pm
Would like it turned off or as an optional setting or based on a bit size?
Jim
jimandi5000
Postby leversole » Tue Dec 17, 2019 3:38 am
Probably optional is better than based on bit size...
leversole
Postby jimandi5000 » Tue Dec 17, 2019 6:25 am
leversole wrote:Probably optional is better than based on bit size...
I will have a look and see if I can add that option. :)
Jim
jimandi5000
Return to Gadgets - Requests
