Using the Dado Gadget on rotated parts
This forum has been created for users to submit suggestions for Gadgets
Postby acs_user » Fri May 03, 2019 3:24 pm
Hello All,
I'm trying to use the dado gadget for cutting qualified tenons in cabinets. I'm having an issue when using it on rotated parts (nested) in some test cut. I know I probably won't be cutting like this for full blown cabinets but was wondering what I'm doing wrong? The dado tool paths on parts that aren't rotated work but the tool paths on rotated parts don't follow the actual dado. I've attached some pictures.
acs_user
Model of CNC Machine: Shop Sabre Pro 408
Re: Using the Dado Gadget on rotated parts
Postby Adrian » Fri May 03, 2019 3:53 pm
I never designed it to work with vectors that are at anything other than 90 degree increments.
Also you have to run the gadget after you've done the nesting rather than before unless you go the extra step of grouping/ungrouping and associating the vectors with layers so automatic toolpath creation can work.
Postby acs_user » Fri May 03, 2019 4:39 pm
That explains it. Thanks.
acs_user
Return to Gadgets - Requests
